header question....help quick!!
Old Apr 17, 2001 | 05:31 PM
AirN1's Avatar
i bought a set of edelbrock headers for my newly built 350 thats going in place of my old 305 on my 84 TA....my question is what do i do with all the emissions lines that were on the old manifold? do i need that stuff? what other emissions do i need to get rid of....since emissions tests are never done here....
and should i get rid of the cat. converter? or gut it out?.....anyhting else i should do?
i wish i could put true duals on but thats probally lots of work
thanks
Old Apr 17, 2001 | 09:18 PM
buddha6974's Avatar
Here in MI you dont need any of it. i pulled my smog pump, all associated tubes and vacuum, unneeded vacuum lines to the carb, and manifold, and ran a straight exhaust instead of a cat. My camaro is carbureated so i pulled the comp as well. Remember, you only need three vacuum lines, 1 to your power brakes, 1 to your vacuum advance distributor, 1 to your wipers. if you run an automatic tranny you need one to that as well.
I am all for a clean, uncluttered encine compartment.
Dan
Twin_Turbo
Mar 14, 2016 10:10 PM
Chad Speier
Sep 24, 2015 12:32 PM
corey8084
Sep 17, 2015 02:56 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
