Where do i put the o2 sensor from my cat i took off
Old Dec 30, 2002 | 12:31 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Where do i put the o2 sensor after i put a 2 foot pipe instead of the catalytic converter???
Old Dec 30, 2002 | 01:00 PM
bennyhonda's Avatar
Car: 1992 Camaro RS
This is on a thirdgen right? The O2 sensor should be on the driver side exhaust manifold. There shouldn't be any factory sensors on or around the cat, unless you swapped in an LT1 or LS1 from a fourth gen.
Old Dec 30, 2002 | 01:09 PM
tbfirebird's Avatar
Engine: ??????????
theres a rubber hose coming from the cat on the passanger side of the car.
Old Dec 30, 2002 | 10:19 PM
MdFormula350's Avatar
the only thing that goes to the cat is the air tube that i know of, from the air pump..
Old Dec 30, 2002 | 10:37 PM
tbfirebird's Avatar
Engine: ??????????
so what do i do with that??
Old Dec 30, 2002 | 11:16 PM
wyldbillracer's Avatar
throw it away, you will not need it anymore
Old Dec 30, 2002 | 11:27 PM
yeah you could remove the smog pump and all the stuff connected to it, or just leave it there, if that is the air tube its just air coming out... so do you have an o2 sensor on the car still?
Old Dec 30, 2002 | 11:49 PM
tbfirebird's Avatar
Engine: ??????????
maybe maybe not i might just leave the cat on and i might take it off dont know if i can get the hole pipe with out haveing to buy 2 or three different parts i will take it off.
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
