Q's on I-pipe flange for stock ~3" exhaust/cat
Old May 1, 2001 | 12:11 PM
james_fearn's Avatar
is the flage welded or is it loose. I'm converting my exhaust from the 85-type 4 bolt flange to the later 2-bolt flange. The 85 type flange is welded so it cannot be rotated but on my new flowmaster setup (3", single in/out) the I-pipe end fitting if flared indicating that the flange to the cat is a "loose" piece and not welded like my stock exhaust is. If the later flange is indeed loose then I will have to get one to make it a true bolt on.
I'm sure a lot of people know if the I-pipe to cat flange is loose or welded on the I-pipe.
James
1985 Z-28 305 TPI 223,000+ mi., Original Eng.,T-Tops,Blue/Grey
STB,SFC,GW "wonderbar",145 Speedo
Old May 1, 2001 | 12:46 PM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
On both my '87 and '89 IROCs this flange is 'loose'..........
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF, 53kv coil, MSD wires.
Old May 1, 2001 | 02:20 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
On the cat itself the flange is not moveable, on the I pipe it is loose so it can be rotated to line up w/ the flange bolt holes on the cat.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old May 1, 2001 | 07:26 PM
thanks, that was what I was looking for.
James
Jeremys87
Jul 14, 2022 09:08 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Genopsyde
Oct 7, 2015 08:35 PM
Chiknhawk
Aug 23, 2015 05:54 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
