Bolt removal question
Old May 7, 2001 | 10:27 PM
KW87GTA's Avatar
I removed my emissions controls, and I wante to remove the AIR pipes that come from the CAT and the Headers. I just can't get to the bolt on the back of the engine that is a clamp on those two pipes. Has anyone been able to remove these things, and what tool did you use. Thanks. What a headache.
Old May 8, 2001 | 01:54 AM
Phil87IROC's Avatar
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Yep! I feel your pain!! My '89 IROC has just one cat, so it had just one tube. I got to the clamp on the back of the passenger head from below......and above. That bolt has a nut on it too that holds the clamp and some grounding wires. My Dad and I ground a 14mm open end wrench so that it was very slim (thickness). He put it on the bolt head, not the nut, from above, and I got a long (12") boxed 14mm wrench from below on the nut and got it loose and removed the clamp, pipe and ground wires. Be sure to put the wires back.
BTW, I had my exhaust lowered from the manifolds and the starter off as well.
It's a pain, but that's what I did......thanks Dad, teamwork!
Good luck!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, ZZ-9 cam, Edelbrock RPM intake, Hooker SC/LT headers, Edelbrock 750 cfm Carb (#1411), stock T-5, GM 3.42 rear w/Auburn posi.
Ohio Valley Dragstrip Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hyper Chip, gutted MAF, 53kv coil, MSD wires.
Old May 8, 2001 | 05:36 PM
SS-84's Avatar
Car: 1992 RS
Transmission: 700R-4 when it works
Have you thought about, removing the distributor, removing the tranny crossmember and lowering the tranny to tilt the motor back and down for easy access??
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
