anyone using supertrapp mufflers?
Old May 9, 2001 | 09:13 AM
Superblue87Formula's Avatar
I am thinking about running a dual exhuast with two supertrapps on the end instead of trying to squeeze a pair of mufflers under the car, does anyone else use supertrapp muffler/tips?
-=1987 Formula 350=-
Member Greater Cincinnati F-Body Association
Old May 9, 2001 | 10:39 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
I had true duals (2x 2 1/4")with Supertrapps at the ends on my mildly built LG4(cam,intake,carb etc)At first I was using 10 discs and I would blow them out off the core.So I tried it with no discs,lasts a little longer but not long enough I have to change the core every yr also have to repack the PITA fiberglass twice a yr..IT sux..BTW the size is a 4" x 18"(i think) and its stainless.
Daz
Old May 9, 2001 | 10:40 AM
**** that, I just won't use any mufflers
Old May 9, 2001 | 07:34 PM
SUPER-SPORT-CHEVY's Avatar
Well Im tempted to run duals on my firechicken and use supper traps but after hearing Daz's probs I wont now.
Superblue87Formula, I would not recomend not running a muffler. At least go with 12inch glasspacks and glasspacked chrome tips. the 12's can fit anywhere so space is not a problem. the glass pack tips will help alot in sound reduction. On my 85 camaro i have "duals" with 32 inch glasspacks and it is very loud so you need some sound reduction thats why i wanted the supertraps for my bird. At least consider some sort of muffler.
SSC
Old May 10, 2001 | 08:18 AM
purpleworm's Avatar
Dynomax makes a tube muffler like the glass packs. I heard a dual exhaust on a Chevy Xtreme and it sounded really good for a 4.3L
Old May 10, 2001 | 12:37 PM
Kenn's Avatar
I'm running Dynomax bullets with dual exhaust and an X-pipe and it was pretty loud until I got the tune right - base timing is 9deg, with ESC pluged in 15-18deg, TPS @ .52, idle @770, fast chip- I think the X-pipe helps to keep down the noise too
I think with the right tune, tips and a crossover you may be able to keep the noise down with glasspack type mufflers
Old May 13, 2001 | 01:34 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yes, use a muffler or something.
89 RS
Looking For:
87 IROC-Z28 350 TPI
FormulasOnly
Jul 23, 2018 08:47 AM
cstrobel65
Sep 16, 2015 11:54 AM
