Heddman Shorty Headers: Install and other various questions within.
Old May 13, 2001 | 11:40 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
How long will it take to install them? How hard is it? Anything that is going to pose a problem? I got a good deal on some shorty's and well, the deal was irresistable(sp?). My cat. shouldn't be a problem because...my y-pipe as it was so screwed the pipe i stuck through the cat. is about 4-5 more inches longer (towards the bend of the y-pipe). So i imagine that'll fit. I did do a search on the subject but not much came up about fitment and install problems, except the flanges.
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 13, 2001 | 02:53 PM
taliesian's Avatar
I did my heddmans at a friends shop with a lift, I think it only took around 2 hours to put them in. I would like to also say that is in an 84 z-28 with a 77' 4 bolt 350 in it with no smog crap to deal with and very little for wire harness(q-jet gone, have vacumme adv distr)
Old May 13, 2001 | 04:40 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Anyone else? Fitment problems?
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 14, 2001 | 10:59 AM
Superblue87Formula's Avatar
the hard part is getting the old manifolds off!
The drivers side is a little tough to squeeze past the steering column but not too bad.
The passenger side is really easy IF you take out the fan temp switch and put it in from the bottom, from the top it's a bitch to wedge past the a/c but from the bottom it slips right in.
Old May 14, 2001 | 06:17 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
That's what i wanted to know. Thank You.
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 21, 2001 | 02:05 PM
Blue5.71LE's Avatar
I just finished installing a set of headmans.wasn't hard at all. i also went with the headman y-pipe. i suggest you simply follow the instructions.after removing the air box,air tubes, manifolds,and spark plugs. Raise the car up on jack stands,remove the motor mount of the side your working on, tilt the motor about an inch and the header drops right in from the top. replace the motor mount, and repeat to the opposite side, all in a days work.Good luck.
Old May 21, 2001 | 02:06 PM
Blue5.71LE's Avatar
Old May 21, 2001 | 09:57 PM
MikeS's Avatar
blue,
what do you think of that ypipe? i've been thinking of replacing the muffler shop one i've got with the genuine thing. look like it flows good and isn't restrictive?
Old May 22, 2001 | 01:45 AM
JJ's Avatar
JJ
Easy install A little tight on the driver's side for me with an 87 IROC.
Old May 22, 2001 | 08:54 AM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
lol, thnx JJ
89 IROC-Z 350 TPI
-Flowmaster Catback
-K&N Airfilters
-Ported Plenum
-Gutted cat
-!AIR
-Gutted Air Boxes
Old Sep 29, 2003 | 08:16 PM
89Formula350WS6's Avatar
I don't have the directions. Do both sides go in from the top? Do I have to raise the engine on both sides?
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
