More Slp Header problems- Y pipe not fitting
Old May 21, 2001 | 06:51 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Along with the long list of problems I have been having with my slp headers Like warped flanges that I had to have belt sanded, I am trying to put the crossover and y pipe on my single cat '87 Iroc. I slippped the crossover pipe into the y pipe and tryed to put it up to the headers only to find that it is too wide. By that i mean the distance between the two flanges on the y pipe/crossover pipe is about 1 1/2" to 2" wider than where the header flanges are. Any one else experience this? What did you do? Even if it were to fit, the crossover pipe doesnt really mate up with the header and is a little uneven, looking like it might leak. I CANT move the crossover pipe any more because the oil pan is in the way. Anyone have this problem??????
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
Large tube runners
ported plenum
Holley afpr
SLP 1 3/4" headders (not installed yet)
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false
Old May 21, 2001 | 09:33 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I had the exact same problem with the y-pipe but your not going to like how I fixed it! I CUT 1 to 1 1/2 inches out of the y-pipe below the oil pan and re-welded it back together to the correct size.
I don't know what there problem was or is but they need to fix it! Christ, the smallblock hasn't changed size in 30 years!I still like the headers though, I get alot of complements and they sound great too. No leaks.
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Raptor 700R4 Tranmission, Trick Flow Twisted Wedge G2's, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine Belt Setup, Dual IROC Fans, Jamex springs, 16" IROC Rims, 36mm/24mm Sway Bars, Global West Steering Brace. Hotchkis Rear LCA's,Panhard Bar and SFC's.
My Camaro Project
Old May 22, 2001 | 12:31 PM
zz4mula's Avatar
Car: FORMULA 350
Engine: ZZ4
same happened to me. I did the same ,,cut and reweld. I know,,a pain.
Old May 22, 2001 | 03:19 PM
jimbo's Avatar
Car: 1991 Formula Firehawk (Clone)
Engine: 350 with Firehawk Package
...mine bolted right up to to the header flanges, but my headers are 1 5/8"...
...that may be the difference...
jimbo
Mosquito Coast F-Body Association (MCFBA)
1991 Formula SLP350
1999 Trans Am Firehawk
Old May 22, 2001 | 07:54 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I paid to have mine installed and the mechanic that did it had no problems. My suggestion is to put all of the bolts on loosely first, then once you make sure that you have no connection or clearance problems then tighten everything down. Hope this helps
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old May 23, 2001 | 07:49 AM
Engine: 4.0L
<font face="Verdana, Arial" size="2">Originally posted by Pukka:
</font>
You don't understand Pukka, You cannot get the bolts started loosely when it is off by almost 2 inches!
86 Camaro Sport
My Camaro Project
Old May 23, 2001 | 06:11 PM
Lostsol's Avatar
I have had all the same problems as you've all had. For the Y-pipe we cut and welded to fix that, for the warped flanges it was only on the passenger side, I bolted them to a bare head and heated up the primaries hoping that they would relieve the stress and straighten out. It worked to an extent but I still had to double up the gaskets. Where the Y-pipe mates with the passenger header is off and I have a leak there that I'm hoping to heat and bend to solve that leak tommorrow. I do like the headers and the sound, but for the price and the "suggestions" I received from SLP when all these problems surfaced, all I have to say is they were ****-Poor as far as professinalism was concerned. In other words, I was not impressed.
Old May 24, 2001 | 03:27 PM
Transmission: 4L60e
Axle/Gears: 9 bolt
I finally got them done today. I brought the car to an exhaust shop and had them cut the crossover pipe and fix the length. It turned out fine so far. the car sounds alot better especially with my wide open Borla system.
I just wish I didnt have to go through all these problems though. Thanks
1987 Iroc 350
K&N filters
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
Some pics of it at
Old May 24, 2001 | 11:39 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
Another satisfied SLP customer! Not.
If the SLPs cost $200 shipped, I would propably buy them. But than again, I might settle for a cheaper and more user friendly set. SLP-DON'T BELEIVE THE HYPE!!!
Old May 25, 2001 | 12:25 PM
custman87T/A's Avatar
I have the SLP headers and catback and I can tell you that the install of both was simple and everything fit fine. The onl problem I had was the catco cat doesn't have a good slip fit over the slp pipe. It leaked untill I bought a band clamp.
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
drathaar907
Aug 6, 2015 04:20 PM
