Eldebrock sounds like flowmaster????
Old May 25, 2001 | 09:18 PM
vic_V8's Avatar
Car: RS
Transmission: 4L60
Today I was at the speed store and asked about mufflers. The man told me to forget flowmaster because Eldebrock has a warranty and they sound the same. Is he full of it? He didn't say what series muffler. I will get a Ravin exhaust if the other options are more than $270.
late model 91 rs
fully loaded t-tops
red leather
paint- gm red and yellow blend (light red)
custom pink rims
305 tbi 14"x3" O.E,
computer chip, accel super stock plug wires
MTX sub and amp (very loud)
vic_v8@yahoo.com
Old May 25, 2001 | 11:49 PM
AaronK's Avatar
He is full of it. Flowmasters are quite loud. I think the 40 and 80 series are the loudest.
Old May 26, 2001 | 07:30 PM
90Iroc-Zee's Avatar
No way does edelbrock sound like flowmaster. Get outta here, I used to own a 88 RS with edelbrock headers back. Nothing like flows, edelbrock is quiter and a lot nice sound.
1990 G92 5spd LB9 - 3.42
Accel Ignition/Wires (8.8mm), Advanced Timing, Homemade Ram Air, TB Bypass, Ported and Gasket Matched Plenum, Synthetic Motor Oil, 160 Thermo, TPIS Airfoil, K&N Air Filters
14.4 @ 94mph w/2.0622 60ft
Old May 27, 2001 | 12:21 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I haven't ever heard Edelbrock. But I can tell ya one thing. Once you hear a set of Flowmasters on a SBC 355 w/ single plane Holley, Holley 750, Crane single pattern 302 duration solid lifter cam w/.510" lift, your heart will start to beat with the idle. I have yet to hear a set of ANYTHING that sounds like a Flowmaster.
I swear on Granny's grave, I am telling the truth!!! I don't know where I read it, but they actually did a brainwave scan of people listening to Flowmasters compared to other mufflers. The other mufflers caused the same brainwaves as high levels of stress do. The Flowmasters gave the same results as sitting on the beach, reading a book. No chit, I am not making it up. That's a good sounding muffler, wouldn't you say?
92 RS w/t-tops 305 TBI Auto.
170K miles and don't burn a drop o'oil
-K&N Truck filter #1500 w, open ele.
air cleaner
-Dynomax 2 1/2" cat-back
-B&M TransPak
-Jet Stage2 Chip
-180* T-Stat w/ 185* Fan Switch
-JVC CD--Alpine speakers & 4ch. amp
Rockford 2ch. to 2 MTX 12" subs
[This message has been edited by AJ_92RS (edited May 26, 2001).]
Old May 27, 2001 | 11:42 PM
Baron's Avatar
Blowmaster and Edelbrock are nothing alike. I have a 3" Edelbrock system from headers to cat-back with a Catco cat in the middle...it's perfect for my car. Not too loud to be annoying, but loud enough to make the car fun to drive. Can hear the EXPENSIVE stereo crystal when everything's shut, but minus windows and T-tops it roars. Looks good, lifetime warranty, flows wonderfully, and has a classy, more tone, less noise sound of the older musclecars. Edelbrock's website has three sound/video clips on a 4th get LT1. Not too bad. Good luck.
'89 RS LO3- 140,000 miles
14x3 K&N Open Element
Ram Heavy Duty clutch
Edelbrock TES (Jet-hot coated)
Catco cat
Edelbrock 3" Cat-back
Pioneer DEH-P77
Dual .50 caliber machine guns just under ground effects
Coming:
KYB shocks
Edelbrock Strut Tower Brace
South Side Machine subframe connectors
When your buddy reaches for a 10-pound sledge and says "I think we're gonna have to modify the floor pan, okay?" the answer is NO.
Old May 27, 2001 | 11:43 PM
Baron's Avatar
BTW, Flowmaster guys, no offense, flows are great too
Old May 28, 2001 | 08:13 AM
86IrocZ383's Avatar
On a thirdgen, both have a good tone, but the flowmaster is a little louder and had a better sound in my opinion. The only way it is going to sound the best is if you put a straight pipe in for your cat and put a set of headers on. If you were comparing true duals exhaust, edelbrocks are FAR louder than a 2 chamber 40 series flowmaster. The edelbrocks can hurt your ears going under a bridge at anything over 2500 rpms.
86 Iroc, 383 Ported Sportsman II, Ported RPM Airgap, 750 Holley Vac. Sec., Slp 1 3/4, Comp Cams roller 218 224, 10" 2600 stall, Fairbanks 700r-4 W/superflow pro pump, 9" disk 3.70, 12.969@106.54 1.991 60', new times in spring
87 K30 Chevy P/U 355 TPI Crane Compucam, Ported heads TH400, headers and 2 1/2 duals, flowmasters, 8" lift, 36" super swampers, 4.10 detroit lockers,
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Night rider327
Oct 9, 2015 09:25 AM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
