True duals 2.5" or 3"
I am getting a X-Pipe made for my 88' Iroc-Z 350 TPI, it is mostly stock except for hooker Super Comp LT, ported plenium,larger runners, AFPR, Advanced timing,2600 stall,and K&N. So my question is should I go for the 2.5" set up or the 3" set up for the X-Pipe? Thanks for the help.
Dan.
Dan.
Car: 1978 Chevrolet C10
Transmission: Turbo 350
well if you want ground clearance go with 2.5 but if you want badass ness go with 3inch it will slightly flow better and plus just saying that you have true 3 inch duals on one of these cars is sweet, i now can say this, go check out my thread on my 3inch duals.
Car: 88 Camaro
Engine: 355
Transmission: TH-350
Re: True duals 2.5" or 3"
Dan.
Dan.
Transmission: 4L80E/4L80E
Chevy High Performance Magazine, latest "My Generation Camaro" article, they dyno'd (actual dyno test, no bench racing) their newly-built (carb'd) 350 with Edelbrock TES, single 3" cat-type y-pipe and single 3" muffler, at 380 HP.
If you "need" a 3" X-pipe on a "mostly stock" 350 TPI, you also "need" some help.
Sorry, guys, what most think is "needed" exhaust-wise just doesn't stand up to reality. Those SC LT's are one example, I'm afraid. Huge sacrifice of ground clearance and dollars for what is most likely zero benefit.
I am not worried about ground clearence issues like everyone else is, It is how careful you are and where you drive. I was told the lowest part of running duals would be the collecters. I am going to be running bullets so I am not worried at all about the clearence. Thanks for the input guys.
Dan
Dan
well ill go take some pictures of my ground clearance, i dont have much with 3in and its not the collectores... its the piping over the tranny K-member.
Car: 88 Camaro
Engine: 355
Ben
the rear and... plenty of clearance, and im sorry that you choose to take apart what i did, momar, im happy with the way it flows, it didnt need to me mandel bended because of the slight bends, and im having no problems with it excapt the cops. im happy, tahts all that matters. thanks though.
I'm sorry, I didnt mean to bad mouth your exhaust. I think its pretty cool but I just couldnt see driving somthing that low around here. Maybe the roads are better where you are. I was more just trying to give a warning to anyone who didnt have the motor that needed that and just wanted to do it to be cool, because I have seen several times when people have had duals that hung real low that the soon regretted going with duals. What kind of motor do you have ahead of that anyway.
Ben
Ben
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
It rare I give an opinion on something but squeeks, that is hideously low ground clearance (I wouldn't be able to get up my driveway with that) and it looks awful from the rear. Our cars aren't symmetric (sp?) in the back and your setup amplifies that severely.
Squeeks, I agree that you should try to have the mufflers realigned somehow. I dont know if you will be able to make it look any better from the back though because of the lack of symetrickness (not spelling but a word modified to my liking). If it were possible you would have to probably turn them flat and move them both to the passenger side to do it.
Ben
Engine: TPI 305/ v6
Thank you momar, I appreciate that.
One of my favorites (aside from mine since I made it) has to be *******. The only drawback to his setup is price but, on his car & his setup, it's justifiable (close enuogh on the sp.
You can't turn oval mufflers flat where they are on squeeks car because there is only about 7½" of width to put a muffler in that position. That's why I ended up making mine (that and I'm way to cheap to buy dynomax bullets for the price they ask).
I have to say the one thing I don't like about my exhaust is it's not as quiet as I wanted it to be when you're getting down & dirty. I guess that's a 'cake & ice cream' thing though. It is bassy 'stock' quiet at idle though. I may end up making a new 'crossflow' muffler that fits the stock location but is dual inside (I'm sure someone really cares aside from me
I found out my cousin has a digital vid cam so maybe in the near future, I might get some vid/sound of my exhaust up. Don't hold your breath though
).You can't turn oval mufflers flat where they are on squeeks car because there is only about 7½" of width to put a muffler in that position. That's why I ended up making mine (that and I'm way to cheap to buy dynomax bullets for the price they ask).
)I found out my cousin has a digital vid cam so maybe in the near future, I might get some vid/sound of my exhaust up. Don't hold your breath though
You need to check out my exhaust setup at http://www.91firebird.0catch.com/ my muffler has a built in x pipe and i have good ground clearence with dual 2.5
sorry then momar i thought you were taking a shot at me,
i have a built 355, all the good things, i have domed pistons, firged 5.7 rods, a billet crang, stock heads but ported/polished w/ 1.94 valves, edelbrock performer intake and 600cfm carb. soo im putting on some new heads thats the only thing i can really do for naturly asperated engine. any ways the roads aroun here are decent.
Deadbird, i know, the guy that did it did the best HE could, so im having a friend take off the mounts on the back and reallign them, i nitoced that but for now i dont really care because my car ISNT a show car. its just for fun.
Honestly dual 2 1/4" will work fine for most any streetable 350 ( under 500 horse). Even on my 383 2 1/4 duals had quite a bit more low end torque than dual 2 1/2's. Dual 3" pipe on any smallblock will cost you power, yes is sounds cool, but you will lose most of your bottom end. I have had most combos on my car, stock, single 3", dual 2 1/4, and dual 2 1/2 and dual 2 1/4 worked best and it was easy to build and very quiet.
Ben
Yes, they all had an h-pipe, but like I said the 2.5 duals took a noticable amount of my low end torque away. I was really wanting to lose some of the bottom end for traction purposes and thats why I went to the 2.5's.
