Q for Flowmaster American Thunder Series...
Old May 15, 2001 | 12:24 PM
Mike 25th's Avatar
I just instlled my system and the pipe that goes over the rear axle in so large that it barely clears the braces back there. Did anyone have this problem? What were the solutions.
92 Z28 - 5.7 - Black/Grey Leather
Macewen White Faced Guages
SLP T-RAM, 24lb/h Injectors
Accell 52mm Throttle Body
SLP 1 3/4" Headers and Cat Back Sys.
SLP T-RAM Registry & Custom Decals Here!
Old May 15, 2001 | 02:20 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
I don't know, but how does it sound on your car, from looking at your setup it should sound kick a** and keep getting better.
89 RS
Looking For:
87 IROC-Z28 350 TPI
[This message has been edited by IROCZTWENTYGR8 (edited May 15, 2001).]
Old May 15, 2001 | 03:51 PM
camaro6spd's Avatar
YOU HAVE T-RAM? I will give you 5,000 for it....
Old May 15, 2001 | 04:07 PM
branz28's Avatar
Car: 1989 IROC-Z
Engine: 383
Transmission: Pro-Built 700R4 2400 ACT Stall
Axle/Gears: 2.77 Borg Warner 9-Bolt
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
YOU HAVE T-RAM? I will give you 5,000 for it....</font>
89 IROC-Z 350 TPI
-Flowmaster Catback
-Performance Resource Chip
-700R4 (Rebuilt) Too much done to actually list
-K&N Airfilters
-Ported Plenum
-2.77 Gears (not much to brag about but eh, its there)
-MSD 8.5 mm plug wires
-Gutted cat
-!AIR
-Gutted Air Boxes
Old May 16, 2001 | 09:17 AM
Mike 25th's Avatar
Car sounds great when the pipe isn't rattling off the crossmember. Carefull... I'd sell the whole car for $12,000 Just think, that's only $7,000 for a fully optioned '92 with 50,000mi, the T-Ram and old TPI and my newly purchased C5 wheels.
Anyway, someone answer the question. I think I'm just going to dent it like my header just enough to clear...?
Old May 16, 2001 | 09:56 AM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
Mine was tight going over and around just about everything. I don't have any problems with it hitting any crossmembers though. The one thing that I did have to do was use some stiff wire (coathanger) to tie back one of my brake lines so that it didn't melt to the pipe. It started to, but luckily I caught it before it had time to do any damage. Have you tried shifting it around by moving some of the slip fit pipes further in to tighten things up a bit more? I had to do some serious maneuvering to get mine in properly. Good Luck
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace, One Loud Stereo!
Old May 22, 2001 | 12:23 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
Hang the whole system but don't tighten the clamps. Start tightening the clamps, starting with the cat and then the first intermediate pipe section. Then move your way back. I had the same problem with the brake line also. Once it is all tightened drive it around. Retighten the clamps after a few days. You might have to weld the first section on the intermediate pipe after the cat. Mine would blow apart every couple of miles or so.. the first time it happened i had no idea what the hell was going on.
  • 89 Formula 305 WS6
    SFC's, LCA's, Air Foil
    Spohn Panhard Bar
    Flowmaster Cat Back, Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
Old May 29, 2001 | 03:44 PM
TOPLESZ's Avatar
Car: 2002 Camaro SS
Transmission: 6 speed
Axle/Gears: GM 3.42
I had the same problem on my 92 z28 convertible... had a muffler shop heat that pipe to get it away from the frame, but on any substantial size bump the rear axle travels enough to bump into the pipe. It seems that the intermediate pipe slip-fit is not on far enough...but it most definitely is! Even went so far as to have some of it welded and bent even further away from the axle but to no avail.... sadly, the flowmaster will come off. I'm gonna try the Hooker this weekend...see how that goes.
1992 25th Anniversary z28 Convertible
dmccain
South East Region
Sep 30, 2016 06:23 AM
Night rider327
Oct 9, 2015 09:25 AM
meeklay812
Oct 1, 2015 03:46 PM
89fast5oh
Sep 8, 2015 09:55 AM
84 TA NV
Sep 6, 2015 08:02 PM
