catalytic converter is crazy
Old May 30, 2001 | 02:34 PM
korbin's Avatar
ok...mine makes sounds!! it rattles when it heats... what could have caused this??
oh and to replace it, the line going into it(rather tiny tube), what exactly does that thing do?
Old May 30, 2001 | 05:09 PM
Ezey Go's Avatar
Just gut the cat.Youll be happey you did.Im pretty sure the small tube has somthing to do with smog but I could be wrong.
Old May 31, 2001 | 12:03 PM
korbin's Avatar
ok ok gut the cat...how am i supposed to do that? also, Indiana doesn't have state inspections on vehicles so it doesn't matter if i have the cat or not... does gutting the cat make it to where it acts like it's not there?
Old May 31, 2001 | 12:21 PM
WS6 Berlinetta's Avatar
The tube pumps air into the cat to help burnup the exhaust. If you gut the cat stuff a pipe into it to keep the flow smooth. The inside of the cat is like a perforated ceramic brick that the exhaust runs through with the little tube cutting through the middle it's basicly an exhaust filter. Use a hammer and spike to knock the ceramic out or just replace it with a pipe.
R
'84 360ci WS6 Berlinetta
Fastest Berl In Ahhh De Lan!!
WWW.SDFB.ORG
PurelyPMD
May 5, 2016 04:57 PM
Eric-86sc
Sep 22, 2015 08:25 PM
Camaro_383
Sep 11, 2015 11:28 PM
m00n420
Sep 11, 2015 02:39 PM
89fast5oh
Sep 8, 2015 09:55 AM
