what do hooker headers look like?
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i was wonderin whta they look like and if i would have to buy a y-pipe for them if i got them??
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
best E.T. (dont laugh) 15.997 @86.04mph
http://www.geocities.com/K_towngangsta
which ones? long tubes? shorties? a part number is essential, different #'s come with different things.
89 RS (supposed 350) TBI auto Hooker SC/LT headers Open element 3in K&N CVT protorque mini-starter
Daily driver 91 RS auto LO3 63k
Car: 1984 Trans Am
Engine: Vortec 355
the headers part # is 2460
Transmission: 4L80E/4L80E
Their 2055's are shorties that come with y-pipe, AIR fittings, and O2 bung. About $350 from Summit (not in catalog but will come up on a search of the web catalog). Coated add $150 (I think - I got black painted).
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. 0.030 over 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlock header mufflers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, LT MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1/95.5 @ 5800' Bandimere.
The 2460's are the shorties. They come out approximately where the stock manifolds do as opposed to running all the way under the car. They do not come with a y-pipe and if you get them there will either need to be some serious modification to your existing exaust or it will need replaced. However, if you are shopping for new exhaust the 2460's are very easy to put on once you get everything else off. It only took me about 2 1/2 hours working by myself for installation after the manifolds were removed. The only complications were moving the brake lines about an inch and moving the starter wires. Good Luck.
Car: 1984 Trans Am
Engine: Vortec 355
ohh
hmm
well i think i will go with the other ones
those 2055's i think is what he said
and thanks for the help!!!
hmm
redformula88
Oct 14, 2015 06:08 PM
Chevykid810
Sep 28, 2015 12:57 PM
