can i modify my muffler?
Old Jan 22, 2003 | 09:54 AM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
i was just wondering if there was anyway you could modify your muffler to make a different sound? like gut it? or put turn downs on the muffler? right now im running a stock muffler and i cant afford a cat back right now so im trying to find a free way to change the sound untill i can get a cat back
Old Jan 22, 2003 | 10:19 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
Drill some 1/4 holes in the casing. Other than that, there's not much you can do.
Old Jan 22, 2003 | 10:27 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i wouldn't drill holes.
but by changing the tail pipe diamator, it should change the tone.
Old Jan 22, 2003 | 01:25 PM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
i cut some notches in the pipe before it enters the muffler. it's definitely louder and deeper, but it doesn't sound anything like a good aftermarket exhaust setup. i like it, and it'll do till i can afford a new exhaust system too.
Old Jan 22, 2003 | 01:59 PM
bad_ta_05's Avatar
Car: 85 trans am
underdave could you explain a little more? u just cut notches out of the pipe from the car to the muffler?
Old Jan 22, 2003 | 11:47 PM
underdave's Avatar
Engine: 305 TBI
Transmission: auto
i just took a grinder and cut (2) 1-2 inch notches in the pipe right before it entered the muffler (but i didn't cut it completely off). that way, some of it goes thru the muffler and some of it doesn't.
it sounds kind of "dirty" loud, but in all honesty i like it. and if i ever decide i'm tired of it, i can just spot weld the notches closed.
the only bad thing is that sometimes i get a wicked whiff of exhaust fumes that almost knocks you out (good thing i love the smell of exhaust though).
Old Jan 23, 2003 | 09:34 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
good thing exhaust fumes aren't harmful
Old Jan 23, 2003 | 12:22 PM
underdave's Avatar
Engine: 305 TBI
Transmission: auto
exhaust fumes they not do no damage to my brane at all yet.
but here's a question: if i someday run straight pipes off the headers without a cat or muffler, will the fumes be that much worse? a friend of mine had a camaro without a muffler and cat and i don't remember the fumes being as strong as they are on my car.
Old Jan 23, 2003 | 02:54 PM
82camaro's Avatar
Car: 82 camaro SC
If it's running real efficient, the exhaust fumes won't be that bad, regardless of the cat. CO (carbon monoxide) has no smell though
Old Jan 23, 2003 | 05:48 PM
Marc 85Z28's Avatar
Old Jan 23, 2003 | 07:40 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
My friend bought a 92 B4C that sounded REALLY REALLY good. Its sounded mean, very loud, and very throaty. But the guy only said "It has a flowmaster muffler". Im like why is his 80 series muffler a little louder and so much different sounding then my 80 series with a catback.
Well it turns out the muffler had a hole in it. He got it patched and it sounded way quieter, esp because he only has a muffler and no cat back. So we are all telling him to put another hole in it
Old Feb 1, 2003 | 03:33 PM
irocbirdbuilder's Avatar
Car: 91 Camaro RS
Engine: TBI
im building my buddy a ***** muffler(more of a huge tip) out of the muffler that fell of our zamboni at work. it's 6"diameter 20"long i gutted it and am getting it chromed we cut off his stock muffler and held this up to it and i was honestly supriseed how loud it amplified it. i am tring to get some big tail pies for mine the sysem is 2.5" but the muffler openings are about 3.5 then im going to replace my 5in dia. tips with long ones to give it that big mouth look
Old Feb 1, 2003 | 03:48 PM
Dan88IrocZ's Avatar
CUT OUT!!!
Old Feb 3, 2003 | 06:28 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
change the tips.. cut off the stockers were the come off the muffler and put on something bent a little different (you'll have to experiment here) and some nice big tips. That usually makes it a little louder and ALOT throatier.
Old Feb 3, 2003 | 08:57 PM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
if i weld my new muffler to the i pipe coming from the cat will it pass PA inspections?
and also i bought my flowmsater off of ebay and the guy that cut it off bent the i pipe inlet so that is was more oval than circular
is there something that i can do to get the inlet back to original condition?
Old Feb 3, 2003 | 09:19 PM
kfoley's Avatar
Car: '85 Z28
You can use a pipe expander to bring it back to it's original shape.
Old Feb 3, 2003 | 09:26 PM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
really...very interesting i never even knew such a thing existed...were could i find one and how much will it cost?
Old Feb 3, 2003 | 09:33 PM
kfoley's Avatar
Car: '85 Z28
Most big auto parts stores should have them. I would reccomend getting a higher quality one since the lower quality ones have a tendency of breaking. The tools aren't cheap especially for a good one, so unless you plan on using a few times, I'd just take it to a muffler shop and they'll be able to do it for next to nothing.
Old Feb 3, 2003 | 10:08 PM
90v6rs's Avatar
Car: 1990 RS
Engine: 3.1 MPFI
i searched for expander and all the pics show it making already round opening larger....no pics of re-shaping
whats up with that? will this still work?
Old Feb 4, 2003 | 02:33 AM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
lol Mark...
>umm.. save up and buy some Vortecs! made by cherry bomb! I got them and they are great! Nice deep rumble.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
