True Duels
Old Feb 4, 2003 | 09:07 AM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
True Duels
I have an 89 camaro and would like to run long tubed headers into an x pipe then dump it before the axel. Is this posible? I would also like to drop my car 1 1/2 inch with the ebach springs. Is any of this going to work? If any of you have pictures of this please post I am lost.
Old Feb 4, 2003 | 11:05 AM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
there have been numerous topics on here about dual systems and systems with x pipes. try doing a search...
Old Feb 4, 2003 | 01:06 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
yup, that will answer most if not all of your questions.
Old Feb 4, 2003 | 01:13 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Especially lately. This topic has been beat to death 6 or 7 times in the last month.
Old Feb 4, 2003 | 01:28 PM
Momar's Avatar
Yup, you can find info about it if you search, but I will tell you that you will probably need to choose one or the other as far as duals or lowering the car unless you want to scrape on everything you come across.
Ben
Old Feb 6, 2003 | 11:43 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
You need all the ground clearance you can get with true duals. Trust me, I know... If mine was 1.5" closer to the ground I would scrape a lot.
92camaro350cci
Oct 14, 2015 09:29 AM
okfoz
Oct 13, 2015 02:19 PM
mattcanty
Oct 12, 2015 11:08 AM
91 SrS
Oct 7, 2015 04:32 PM
paul_huryk
Oct 1, 2015 04:27 PM
