pipe size
Old Feb 17, 2003 | 04:32 PM
The00night's Avatar
pipe size
I have the super comp shorty headers with the y-pipe im going to put the muffler right after that(Delta flow 40 series). but im not sure if i should run a 3 in. pipe to the back then split for the two pipes or run 2.5 in. side by side to the back any suggestions.
Old Feb 17, 2003 | 05:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Single pipe would be easier to route and less expensive. The difference in flow would be minimal assuming this isn't some high-reving, firebreathing beast.
Old Feb 17, 2003 | 07:47 PM
406-Z's Avatar
Car: 87 IROC Z-28
Engine: 406-Mini Ram-AFR 195's-DFI Gen 6.32
Transmission: 700-R4 w/Art Carr converter
Axle/Gears: 9" - 31 spline - 3:89
The00night....I will assume the headers have a 2.5" collector and the Y-pipe is 2.5" as well. So to keep the velocity up you need to figure the cubic inch diameter of the pipes in question. A 2.5" pipe has a cubic inch diameter of 4.90 times 2 pipes is 9.80 cubic inches. A 3" pipe has 7.06 CI dia so it is considerbly less than the 2 2.5" pipes. A 3.5" pipe has 9.62 CI dia and would be the best for velocity and less restrtictive for a 2.5" to 3.5" back out to 2.5" system.
I must agree with five7kid also. If it is a run of the mill the difference will be minimal.
Old Feb 17, 2003 | 09:40 PM
The00night's Avatar
The engine is a very strong 355 how strong not sure yet. 10.5-1 compression if that helps any. its the 3 in. y-pipe and colector that is on my particular ones.
customblackbird
Oct 1, 2015 04:30 PM
Linson
Sep 21, 2015 01:08 PM
Brian Anderson
Wheels and Tires
Sep 12, 2015 06:12 PM
Camaro_383
Sep 11, 2015 11:28 PM
m00n420
Sep 11, 2015 02:39 PM
