Jethot Coating WOW!!!
Old Feb 26, 2003 | 08:36 PM
  #51
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Here's what my headers cam with.......
Old Feb 26, 2003 | 08:46 PM
  #52
92GTA's Avatar
Not at all what I got from SLP...
Old Feb 26, 2003 | 09:00 PM
  #53
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Dunh, dunh, dunnnnnhhhhh.........the plot thickens. I think SLP may have sold the engineering for there headers
Old Feb 27, 2003 | 08:53 PM
  #54
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
so has anybody been able to locate a set of headers like these that i can buy, i don't care if they are accel or slp, i just really like them they are something difernet. hehe
Old Feb 28, 2003 | 05:43 PM
  #55
justinhebert's Avatar
Just got my headers coated here in calgary alberta. They look pretty good. $150 cdn not too shabby ehh.[IMG]header.jpg[/IMG]
Old Feb 28, 2003 | 05:50 PM
  #56
Old Feb 28, 2003 | 07:03 PM
  #57
bigals87z28's Avatar
Car: Check The Sig
what kind of headers are thoes and did you send them out to somewhere or was it a local shop?
Old Feb 28, 2003 | 11:24 PM
  #58
They are hedmans. Its the only shop here in calgary that does them. They are coated in and out im impressed.
Old Mar 1, 2003 | 12:39 AM
  #59
Car: Check The Sig
thoes are the ones i want!!! did u buy them and then send the headers to the shop or did u order it through the shop? i can see if some shops get mad if you dont buy it through them. they look killer!! did you get the y pipe for them, and did you get that coated?
Old Mar 1, 2003 | 08:27 PM
  #60
I bought the headers and y-pipe at a different place and brought them to Top Gun Coatings. Header part # is 68470 and y-pipe is
#17470.
Old Mar 1, 2003 | 09:27 PM
  #61
Car: Check The Sig
thanks man.. im gunna buy the headers and y pipe from jegs and then find a place that coats headers
Old Mar 1, 2003 | 10:14 PM
  #62
Sickness91Z28's Avatar
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Does anyone know how Jet Hot coats the inside? I watched the video on how they coat them...and they actually spray it on. I was thinkin "how do they coat the inside if it's sprayed on?"
Old Mar 2, 2003 | 01:56 AM
  #63
Momar's Avatar
Not very well. Well, I dont know if thats always the case, but with my hooker lt's they look great, but they coated them with the removable primary installed and I pulled it out and inside the pipes arent coated very well It appears that they probably flow/spray it through somehow and what it gets it gets and what it doesnt it doesnt. The outsides and what you can see from the ends look great though.
Ben
Old Sep 11, 2005 | 09:12 PM
  #64
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I dont know how JET HOT does it but if they try and spray it they wont get 100 f the inside.
I use a nylon tube on a pressure pot to get 100 of the inside.
The end is caped off and there are pin holes in the tub 360* around it to spray outward as I pull the tub back out of the headers. works great !!
Old Sep 12, 2005 | 02:03 PM
  #65
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
1982chevycamaroz28.....You said those are the hooker 2210's right. Coated. correct?
The 2210s are an exact part correct? so they all have the same primary size?
Thx. I am pretty sure this is a stupid question, but I need to get some very soon so I want to get all the confution out of my head before I fork over the $. Thanks again
Old Sep 14, 2005 | 09:10 AM
  #66
Engine: LS3
bump....
I need to get these header Q's answered soon. THX
Old Sep 15, 2005 | 05:24 PM
  #67
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
check out the sticky at the top of this board.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
redformula88
Oct 14, 2015 06:08 PM
