True duals or sidepipes?
Old Aug 23, 2001 | 03:01 PM
aweichold's Avatar
Is it possible to put true dual exhaust on my 1984 Trans Am? I am putting a chevy 350 in it and I really don't feel like putting emissions or cat on it. I don't have to pass emissions, so it really doesn't matter. I was going to put on my original 305 exhaust manifolds, but the bolt holes won't line up, so I have to modify the exhaust system now to fit my needs. Me and my friend think there might be a way to have a set of sidepipes come out right behind the doors. If anyone has done this to their car, please give me some tips or advaice how to do it?
[This message has been edited by aweichold (edited August 23, 2001).]
Old Aug 23, 2001 | 03:16 PM
z28dan's Avatar
Why would want to do that? More flow does not mean more HP. Running side exiting pipes, your car might sound like a milk truck!
1988 L98
Vette Heads/no EGR
SLP Headers/Y-Pipe
ARAP bin
Old Aug 23, 2001 | 03:19 PM
aweichold's Avatar
I will have mufflers on it. I wouldn't be able to drive it on the street if it didn't have mufflers on it. I had heard that there is no possible way to run true duals under 3rd generation f-body's. I just wanted to know if anyone had tried it or something similar?
Old Aug 23, 2001 | 04:49 PM
87tpi420's Avatar
i gave up on the dual exhaust thing. i wanted to keep my ground clearance to a maximum,and true dual will only fit over axle if you use 2 2.5" pipes in stock location. without expensive fab work and found that a single 4" is plenty of pipe for 1 3/4 primary tubes on the headers. any thing bigger and it is just your headers that are still restricted. i guess it is all personal preferance.....but i think my single 4" from hooker long tubes will be adequate for my 420 ci small block.
but again...it is all personal pref. and you must decide how much you really want to go through to get what you want.
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
[This message has been edited by 87tpi420 (edited August 23, 2001).]
Old Aug 23, 2001 | 05:45 PM
Tas's Avatar
Tas
cast all your preconceptions aside and check out my site.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship :
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Old Aug 23, 2001 | 11:14 PM
Big454blockchevy's Avatar
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
True duals on thirdgen F-bodys is possible . Go for the true dual setup it is not that complicated to install.
383 86 Camaro Z28
10.5:1compression Dart Pro 1 Aluminum heads 215cc>2.05/1.60 valves,400 steel crank,cam specs:224/234 at 050 525/525 lift,3500 stall converter,shift kit,3.42 gears,770 Holley Avenger,Victor Jr. Intake,true dual exh,Hooker headers with 40 series Flowmasters,MSD Coil and Module.ALSO SECOND GEN Z28---mods:454 BBC,.546 max lift(doug herbert cam ) 750 Holley vac sec. ,Edelbrock Performer manifold,Holley electric fuel pump,Hooker headers,Flowmaster mufflers,beefed up 700r4 tranny, 3.90 gears, powertrax unit, B&M console shifter.
Old Aug 24, 2001 | 12:41 PM
iroc22's Avatar
have any of you guys seen the dynomax dual exhaust setup for our cars? I don't know if they are side exit pipes or rear exit, but I am going to find out. Does anybody know where these systems exit?
Old Aug 24, 2001 | 02:35 PM
twistedwedge's Avatar
Car: 87 GTA
Engine: 355 Chevy
Dual 3" here, Hooker super comps, front of car lowered 1" and I have no problems with scraping. You can go with single 4" and be ok, but man do duals sound different and a whole lot better! Just an opinon
1987 GTA 355 inch motor, carbureted, TFS 23* heads, T-56 6-speed, McLeod clutch, 11.3:1, Lunati hydraulic roller .510/.525 lift 232/242 duration @.050 on a 112* lobe seperation, Hooker super comps, Dual 3" flowmaster 2-chamber exhaust with NO tailpipes, 98 Z-28 wheels, Strange 12-bolt rear w/4.30 gears, 33 spline axles and a spool.
This car is driven on average 100 miles weekly... ...Whatever turns your tires.....
Old Aug 26, 2001 | 06:23 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Any1 have any sound files of duals on a Third Gen??
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
Old Aug 26, 2001 | 11:05 PM
Tas's Avatar
Tas
<font face="Verdana, Arial" size="2">Any1 have any sound files of duals on a Third Gen??</font>
yes
-Tas
'89 Formula WS-6
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
Old Aug 27, 2001 | 09:51 PM
Administrator
Can u post it or something??
89 RS
STILL Looking For:
Old Aug 28, 2001 | 05:53 AM
Administrator
Duals also add weight.
89 RS
STILL Looking For:
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
