Help! Fourth gen exhaust can be modifyed to fit third gen camaros, right?
Car: 1991 Camaro Z-28 (Durango R/T)
Engine: 383 L98 W/ HSR
Transmission: 700R4 Tuned Shift 2600 Stall
Axle/Gears: 3.73 10Bolt Posi W/ Al Cover, Disks
I have heard in the past that fourth gen exhaust cat back systems cam be modifyed for use on third gen cars. ( USing 1993 parts on a 1991 camaro) If they can be used what should i expect to have to do to make it work i also have a dual cat set up so will that effect anything? Is this the kind of job i a new car guy will be able to do with basic grage tools or should i have it professionaly installed?
And also:
Has any one ever heard of a magnaflow exhaust catback system. I saw they make them for the fourth gen exhaust set up but can they be used on the third gen. I am driving a 1991 Camaro Z-28 with a stock 350 TPI with dual cats. Will it fit?! Also has any one heard about their strait through flowing exhaust mufflers. no baffles or anything, and all of the exhaust flows in the same direction through the muffler. Does any one know how this should effect horse power. they are also all stainless steel systems so they should last for ever , RIght?
Thanks for the suggestions!
And also:
The only difference in the systems is the way they attach to the catalytic converter. You would need to cut the end of the intermediate pipe off and fabricate some piping to attach to the car. Any exhaust shop should be able to do this.
Linson
Aug 21, 2015 02:12 PM
Vintageracer
Aug 11, 2015 08:13 PM
