Headers on '86 with A/C
Old Sep 10, 2001 | 01:59 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Anyone installed headers on an '86 with A/C..? Im not sure if it'll be different on the later ones as some of the accesories were switched around at some point - but anyways, how the he|| do you get to the last two bolts on the exhaust on the passenger side..? I can't seem to get any room from above to get any tools down there, and I can hardly see them from underneat, even though the Y-pipe is already off...?
Any ideas...?
Thanks!!
Ken
1986 IROC-Z Conv't
17x9.5 TT II's w/ 275/40x17's, BMR stb, Lakewood APR, Jamex 1.5" Lowering Springs
ChevyKen's Cars
Administrator @ ChevyWorld.net
Old Sep 10, 2001 | 03:34 PM
Jza's Avatar
Jza
Those were a pain in the ****, CK. How did I do that last time? I think I slipped the socket onto the bolthead first, then maneuvered the ratchet head onto the socket and about a half hour of turning 30 degrees at a time, finally got it.
Old Sep 10, 2001 | 06:18 PM
david roush's Avatar
Car: 92'Camaro RS
Engine: a loud one
Transmission: bolted to the engine
Next time do what i did. I always had a tuff time tightening my header bolts. So when i took my 305 out and threw it in the trash for a 350, I took a hammer before i installed them and put little dents in the tubes right near where the bolt tightens. Now i have no problem what so ever getting the open end of a wrench on them. Or try grinding a socket down on the outer edge.
92' Camaro RS/Black,T-tops/350 TBI Targetmaster Comp.engine/5 spd/march underdrive pulleys/hedman hedders/3" dynomax exaust/hyper tech stage 2 chip/3.42 gears/K&N air filter
Old Sep 10, 2001 | 09:49 PM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Just get some kid with little hands under your car to put them in for you. All you have to do is stand above and tell them what to do. After they get it in, hand them a few bucks. After you get the bolts in, I just used a combination wrench to tighten them. It is the only thing I had that would fit.
Old Sep 10, 2001 | 11:22 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Thanks guys,
I think Jza's idea is the only one thats gonna work. It isn't getting the socket on the bolt that is the BIGGEST problem, that is to get the ratchet in there + my hand...
I kinda doubt that the kid trick will work either, cause the rest of the bolts certainly have required whatever I have of elbow-grease..
Thanks again folks, I guess I'll just have to take a bucket full of Norwegian "power-swearing" and a socket/ratchet and give it another try...
Ken
Old Sep 11, 2001 | 07:35 AM
custman87T/A's Avatar
I have done it two different ways.
Do it from above the car
1)Use a 1/4" drive with a long socket, a universal and an extension. A 3/8 socket doesn't fit in the small space between the bolt and header pipe.
2)Bend a wrench with a torch into a right angle and you will get little 1/8 turns on it.
Those are the only ways I found to do it on my car with the SLP headers.
87 Black on Black T/A
T-Tops Digital dash
5.0 TPI S/R Torquer 305 heads Summit TPI cam
204/214 @.050 .420/.442
SLP headers and catback
A4 with 3.42 gears
Fully loaded and everything usually works.
Old Sep 11, 2001 | 04:12 PM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
custman87T/A,
Any times on you setup in your sig????
Almost exactly what I'm planning.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
Chad Speier
Sep 24, 2015 12:32 PM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
