Edelbrock TES Headers question.
Old Sep 10, 2001 | 01:22 AM
chevyguy8's Avatar
My headers should be here tomorrow and I read in another post that the black color they have is just an under coating thats why they burn off to that ugly brown/white shade. I was wondering if this is true and if so then would any high temp spray work? I cant coat them cause I dont have the cash. Im pretty sure that even with the high temp spray they are still going to turn bad though, right?
Also what kind of improvements should I see with these and my stock cat and cat-back? or should I just wait till get a 3"cat and cat back?
91 Camaro LO3 RS 5-spd
Open air element,ACCEL 8mm wires w/cap n rotor, K&N filter, flowmaster, Edel. TES Headers(on their way). dual fans.
[This message has been edited by chevyguy8 (edited September 09, 2001).]
Old Sep 10, 2001 | 10:59 AM
iroc5speed's Avatar
I think even the high temp spray won't hold, but it may take a bit of time for it to wear off. I'd say just stick them on there and just get some new coated headers when you get the money. SLP of course....but wait to get those after your 3" exhaust.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
Old Sep 10, 2001 | 01:26 PM
vjo90RS8's Avatar
Car: 2002 Z28
Yes it is true, i put my TES headers on a week and they are already a whitish color. After they are installed you will get a lot of white smoke coming off the headers, it is normal, it is just the paint burning off.
As far as the rest of the exhaust, wait and install everything at the same time. I just installed some TES, a 3" catco, and a aerochambered cat back but i have only been able to enjoy it for about a 30 min because i accidentally knocked out the wire to the fan switch during installation, my car overheated and melted a hose nipple on my heater control valve and i lost all my coolant. Gonna fix that today.
I did notice a very small lose in low end power which is very common but i did feel a lot more pull once i hit 2500-3000 RPM and the sound is great, and is a lot of fun to drive, cant wait to get it fixed.
You will also need a set of new plug wires, i used MSD Heli Core universals, so that you can route them around the VERY HOT headers, they worked great.
Just ask if you need any more questions
1990 5.0 TBI
1 5/8" Edelbrock TES headers, 3" Catco hi-flow series cat, 3" Aero-chamber cat-back, K&N 14x3 flat based open element, MSD 8mm Heli-Core plug wires, AC delete
Old Sep 10, 2001 | 02:54 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I put some 1200* black ceramic coat spray paint on the headers and it lasted about 2 weeks and now is starting to burn off. Summit does sell spray for up to 1500* so maybe I'll try that and see if it holds up.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Sep 10, 2001 | 05:05 PM
CobraKiller's Avatar
Car: 88 IROC-Z/00 GTP/05 VUE Redline
Engine: LB9 305/3800 SC/3.5 SOHC V-TEC
Transmission: A4/A4/A5
Well I've had the Edelbrock TES headers on my 5.7 IROC for about 3-4 months now and for the first week they smell real bad with the paint burning off them(and a few plug wires in the process). After that they turn a white/grey/brown color. They sound decent but they're just too restrictive and a waste of money in my opinion. I learned the hard way. I'll be going with the hooker super competition L/T ceramic coated headers pretty soon. They may cost $650 but they have a lifetime warranty against rust and are arguably the best headers on the market right now.In my opinion edelbrock has nice intakes but their exhaust line needs some serious work..
Old Sep 11, 2001 | 04:53 AM
EvilCartman's Avatar
Car: '82 Z28
Take some laquer thinner and wipe the black shipping paint off then spray with high temp stuff. Mine are still black after a year of use.
'82 Z28
LG4 305 .030 over, performer intake, holley street avenger 670, xe 256 cam, tes headers, 3 inch single exhaust, spintech muffler, 14 x 3 inch drop base k&n.
Old Sep 11, 2001 | 08:59 PM
chevyguy8's Avatar
I'll try that.
Thanx
Open air element,ACCEL 8mm wires w/cap n rotor, K&N filter, flowmaster, Edel. TES Headers(not installed). dual fans.
Old Sep 11, 2001 | 11:22 PM
Dan87IROC-Z's Avatar
Yeah, I just wiped them off after all the paint had burned off, then they are a nice flat black color, they look really cool.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Accel High Flow TPI Baseplate, Edelbrock TES 1 5/8" Headers, Catco 3" High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, Jet TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET: 14.32 @ 97.7mph
(corrected for elevation)
Old Sep 12, 2001 | 02:14 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I also tried to put a high temp (1200+) spray on too. It started to crack soon after I started the car. It's been about 7 months now and parts of the paint is left but you can still see the white metal showing. The paint on the air tubes did stick tho.
I wouldn't waste my time or money on spray painting them again.
Old Sep 12, 2001 | 02:21 PM
FlameRedMetallic's Avatar
don't blame the headers for turning white when u morons don't coat them right! the coating that is on them is for shipping purposes only. you really should sandblast them and paint them with a good quality paint. mine look great after 2 years. do the job right and you will be pleased with the results.
86 IROC-Z
305 TPI
700R4 W/ shift kit
3.23 gears
T-Tops
maroon with gold stickers and rims/ black interior
43,000 miles
flowmaster exhaust, edelbrock headers, gutted airbox, converter, and MAF, K&N filters.
soon to come are 3.73 gears and subframe connecters.
Old Sep 12, 2001 | 09:29 PM
chevyguy8's Avatar
What kind of good quality paint do you recommend?
Old Sep 12, 2001 | 11:14 PM
it has been 2 years ago but i think i use some kind of vht high heat engine paint. like 2or 3 coats or something like that
86 IROC-Z
305 TPI
700R4 W/ shift kit
3.23 gears
T-Tops
43,000 miles
Old Sep 15, 2001 | 02:41 PM
Car: 99 Formula
Axle/Gears: 342
Sorry for being a moron, but I'm sure it is hard to sandblast the headers while they're in the car, I didn't know before hand that the paint would wear off, so I just figured I would try some high temp paint and see what happens.
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
Hotrodboba400
Dec 10, 2019 07:07 PM
corey8084
Sep 17, 2015 02:56 PM
bamaboy0323
Sep 12, 2015 07:14 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
