1 in 1 out is better???
I have heard that when you have a single exhaust pipe you get better flow when you have only a single outlet on the muffler instead of dual. Is this true??
Later,
Vomex
'89 GTA 5.7L TPI
Later,
Vomex
'89 GTA 5.7L TPI
depends on the muffler design. I'm sure there are some single in out muffler that flow better than single in dual out and vice versa. Its a lot uglier than a dual out version so most people won't do it.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
[This message has been edited by Tas (edited September 23, 2001).]
-Tas
'89 Formula WS-6
:Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
the reason they say that is because on the ones that exit on both sides at the rear, (such as flowmaster 80 series) one of the tips routes exhaust so that it has to turn 180* while the other goes straight out.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
- David
Car: 1992 Z28
Engine: 355
When I originally started modifying my GTA I had this same question so I called Flowmaster. The tech I talked to said, and I quote, "Cross flow mufflers suck". Needless to say, I went with the Force II kit.
92Z28
89GTA
92Z28
89GTA
ya the only reason im using cross flow it cause i like the look of dual 3.5" chrome tips. one of these days when i get more performance parts on, i'll put the two on the left muffler back on.
- David
- David
Ya that is most likely the case so I plan on doing True duals 1 in 1 out x 2 =
1989 Trans Am GTA, L98 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27,
- K&N Air Filter
- Dynomax muffler
1992 Camaro RS, LO3 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel - Sold
- K&N Air Filter
Honda engines ROCK, I have one on my lawn mower but I still have to push it.
- K&N Air Filter
- Dynomax muffler
- K&N Air Filter
I've also heard that with dual outs, obviously 1 out is on the same side as the "in" and typically the "in" pipe has to be smaller in that situation.
