Headers on 350 w/A.I.R system?
Old Mar 7, 2003 | 11:21 AM
BWW's Avatar
BWW
I have an 88 trans am with 350 tpi in it. i was considering headers on it but the engine has an A.I.R system which includes 4 small tubes being routed into each exhaust manifold. i dont want special headers that work with the AIR system but instead I was wondering if I could get rid of the whole AIR sytem or at least pinch the tubes shut so I can put normal headers on the engine. any info would help.thanks
Old Mar 7, 2003 | 11:32 AM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Yes you can, just get header without AIR hookups and remove your AIR tubes and smog pump.
Old Mar 7, 2003 | 09:09 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
So I take it you don't have to pass smog right?
Old Mar 7, 2003 | 11:51 PM
joshp14's Avatar
You sure can remove those AIR tubes. I wouldnt recommend it though if you have emissions in your state. A lot of guys (inlcuding myself) have removed or are going to remove the AIR system (which includes the smog pump, AIR tubes, and the plastic box (beside the heater control valve) with a couple hoses going into it).
It sure does de-clutter then engine bay when you remove the emissions system, and it makes your headers actually look like headers...plus you loose a little weight.
For your sake, keep the AIR system...don't destrot it by pinching the tubes, you may need the system in the future, or you could sell it...
Old Mar 8, 2003 | 09:41 PM
BWW's Avatar
BWW
Thanks fellas
Old Mar 9, 2003 | 04:06 PM
Trans_AM_88's Avatar
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
can the state tell if you have no air system if there is no visual under the hood inspection? can they tell if the smog pump is gone with the emission tester alone?
Old Mar 9, 2003 | 11:13 PM
joshp14's Avatar
i have no idea. since iowa doesnt have emissions testing, i couldnt tell ya. you might want to ask someone that has done it before in a state that does emissions testing.
-Josh
Old Mar 10, 2003 | 09:57 PM
MdFormula350's Avatar
after i finish removing a/c, smog is next hopefully.. removing pump / other stuff, and then straight piping the cats and removing air tubes.
i think i can still pass w/o having the air stuff, unless of coarse its a visual inspection which i dont think it is..
Old Mar 10, 2003 | 10:53 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
IMO, emissions will be implemented nationwide at some time or other so why not keep it unless you're really hardcore about racing or need the room. I'll keep mine.
Ed
MustangBeater20
Oct 29, 2022 09:20 PM
Street Lethal
Apr 30, 2019 12:14 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
mustangman65_79
Aug 7, 2015 09:55 PM
