anyone with long tube headers...
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
on a thirdgen, how is the ground clearance? Anyone have any pictures taken under the car....
Thanks...N
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods,looking for a SR ...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Thanks...N
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I built a system on my 1988 Firebird
that has long headers and 2.5" true duals.
It is a welded setup, using 2.5" mandrel bends and straight sections. The crossember
was notched (flanges flatened) so the pipes
pass under with maximum ground clearance.
The left pipe crosses over to the right behind the trans. Then both pipes follow the stock path back and over the axle. Two turbo
mufflers (14X4.5")are mounted behind the axle and the twin tail pipes exit out the back on the drivers side. This system ran the same ET
and 1/2 mph faster in the 1/4 then open exhaust and its quieter than most aftermarket
stuff.
stuff.
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
I got them.........
http://www.geocities.com/cfrios/Phil...l?996948051310
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
Phil87IROC
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
Ground clearance on my car from the lowest point of the header to the pavement is 2 3/16". I lowered my car about 2" from stock height long before I put the headers on.I had to raise the car about 3/4" just for a bit more clearance. I just took pics this weekend on a new roll.I should have them developed this week sometime then I'll post a couple pics.
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Carter 750 carb,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers and open air cleaner,Crane 292 cam,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-piller pods,180* thermostat.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
'91 RS, 375hp 350
