What should I do about this converter??
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
OK, I want to sell this car, but the converter needs to be replaced. It is making alot of noise and the car doesn't seem as quick as it was before this. If u want to sell a car that needs a converter, the buyer will want to knock off lots of money because of it. Should I buy the Summit converter, take the 1 on there off myself and have a muffler place put on the new 1, or sell it like it is or what?? I'm thinking do the Summit converter thing, its all about money though since I want to sell it, so what do u think??
89 RS
STILL Looking For:
An 87 IROC-Z28 350 TPI
89 RS
STILL Looking For:
how do know for sure its the converter, and what kinda car is it
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series
http://www.geocities.com/david_angel_16
- David
89 RS 2.8 V6, when u go next to it and listen u can hear stuff in there when revved, it sounds weird all the time, and I think it feels slower at certain RPM.
[This message has been edited by IROCZTWENTYGR8 (edited October 08, 2001).]
you could just take it off, clean it out, and put it back on, as long the engine is tunned good it should still pass emissions.
- David
- David
I don't think it would pass?? How would u get it back on after taking it off to clean it out when its welded on and I can't do that stuff, should I put a pipe through it??
89 RS
STILL Looking For:
89 RS
STILL Looking For:
Car: '89 GTA
Engine: ZZ6TPI
Go to a muffler shop and have the cut your old one off and weld on a new one. It will cost $100-$150. If the muffler shop will let you bring one in, then that might be cheaper. Make sure you ask them first, some won't do it. Don't gut it or remove it and push your problem onto someone else.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Magnaflow cat-back,
K&N open element,
Car: 99 Formula
Axle/Gears: 342
Why not just hollow it out. I bought my car without a converter and I didn't have the guy knock any money off, I looked at it like a mod. But then again I should have because I had to end up buying one anyways.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
I think I'm just going to leave it the way it is. Could it still be good enough even with all the sounds its making?? It seems a little quieter today, I did alot of revving just to see if it would do anything.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i would take it out throw an old broom handle through it, and put it back on. my friends 86 IROC had a clogged cat...it took away a TON of performance.
-Brian
1991 Camaro RS - ultra blue metallic, t-tops
GMPP 350 HO crate engine - 454 TBI, MSD ignition, SLP exhaust, everything is new
700R4 - 2,400 stall converter, vette servo, shift kit
z28boy.cz28.com
Central New York F-Body Association
z28boy@twcny.rr.com AIM - "Z28 Boy"
Daily driver - <A HREF="http://members.fbody.com/z28boy/grandprix" TARGET=_blank>
1998 Pontiac Grand Prix GT</A> - 2 door, black
-Brian
z28boy.cz28.com
Car: '10 Subaru Forester
Engine: 2.5 Boxer
Transmission: 4EAT
Axle/Gears: 4.44
You will probably sell it for much more if the cat is replaced, when someone takes it for a test drive they will be skeptical... etc. I bet you could make more money than it costs to replace over the price you would sell it at without fixing the problem. Hope that made sense.
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
