Question on Cat and Cat-back system?
Old Oct 25, 2001 | 06:50 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Axle/Gears: 3.23 Posi
Well first off I have an 86 IROC-Z w/305 (only one cat). It is only my summer car so cost is NOT an issue. I want to get the Borla cat-back system. Now will any high flow cat just fit right on to the Borla stuff?? Are they different size pipe ends? (sorry I dont know alot about this stuff)? Oh and what is the best Hi-flow cat? Stainless steel cat is what I am after as well. I also want to get the Spohn SubFrame connectors so would this interfer at all with the exhaust system planned? Thanks for any reply's....
Old Oct 25, 2001 | 07:17 AM
Trent257's Avatar
well i think your exaust is 3", im not sure tho, i just got a catflow cat for 55$, its stainless, im installin it today, if you order the right parts they should just bolt right up
Trent
---Car---
89 Firebird/305 L03 TBI A4/t-tops
Open Element Edelbrock Aircleaner w/ K&N air filter/Summit Chrome Valve Covers
---Stero---
Pioneer DEH-P730 Premium
Infinity 2way 4652 4x6's/Pioneer 4way ts-a6985 6x9's
profile cl640 110x4
----Comming in a few days----
Edelbrock TES headers 3" out/flowmaster American thunder 3" exaust/Catco HighFlow catco cat
Old Oct 25, 2001 | 09:27 AM
Bimma86's Avatar
Car: 1986 IROC-Z
Engine: 355 TPI
Yes it is the Stock 3 inch before the cat but I dont know if it is after? Might be I'll check back later....
Old Oct 25, 2001 | 12:24 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
<font face="Verdana, Arial" size="2">Originally posted by Bimma86:
Yes it is the Stock 3 inch before the cat but I dont know if it is after? Might be I'll check back later....</font>
Stock 3" are you sure about that? I thought our car came with like 2 1/4 or 1/5", then again I could be wrong. Personally for the money the Borla, I've seen in Jegs and Summit and there is a note that it's only the muffler back for our cars for like $400. I would go with the Hooker cat-back, but that's my opinion.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
Old Oct 25, 2001 | 11:55 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
The y-pipe on my car was 3" up to the cat, and then it went to 2 1/2" or 2 1/4" (I don't remember which) for the cat back part.
Although they do have the rear section (muffler back) in both the Jeg's and Summit catalogs, they also have the catback system. The catback from Jeg's is $525.99 and p/n: 157-14888. In Summit it sells for $525.95 and is p/n: BOR-14888. This system has four interchangable plates to adjust the sound and performance levels. Borla makes good stuff, but I have heard many reports that this kit is very poorly made. Usually it comes about 6" shorter than it should be and I have also heard that the tailpipes don't usually line up correctly. For our cars, I would go with Flowmaster, but that is my opinion. It would save you alot of hassle, especially if you are new at this.
As far as Cats go, Random Tech and Catco both make good cats. Summit carries Catco and they have quite a few direct fit cats that are direct bolt ons for some cars. That is what I got and it has been great. Random Tech has good cats, but you will pay almost double ($250+) for one of theirs. Obviously you can get a cat for cheaper if you don't get a direct fit cat, but the direct fit ones will save time and energy. Both of those companies use stainless steel for their cats also. Hope that helps a bit.
Matt
irocet@hotmail.com
drive.to/Stang_Kilr
88 IROC-Z -- 350 L-98, 700R4, Flowmaster, Edelbrock Headers, Catco Cat, K&N, MAF Sceens Removed, Airfoil, March Pullies, Comp Cams Magnum 1.6 Roller Rockers, Bosch Platinum Plugs, Accel 8.8 mm Wires, MSD 6AL, Hypertech Cap & Coil, Hypertech Chip, Hotchkis Strut Tower Brace
[This message has been edited by IROCET (edited October 26, 2001).]
MustangBeater20
Oct 29, 2022 09:20 PM
Out-Cast
Aug 22, 2015 07:49 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
