i just ordered my hooker cat-back...any tips on installing it?
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
it sounds like it's gonna b pretty easy besides the I pipe......what is a good way to get it up and over the rear axle and back down?
and i plan on using a car lift so will that make the installation a lot easier??
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
new best E.T. (dont laugh) 15.986 @84.93mph
old best E.T 15.997@86.04
http://www.geocities.com/K_towngangsta
Mods-
K&N Air filter
Mods-
K&N Air filter
If my car was running, I would have just brought the kit to the muffler shop and had them weld the connections and make it hang right. In the kit, something will say that they recomend having all slip fittings welded. But if you're gonna do it yourself, I'd put outlet pieces onto the muffler, then hold the muffler in place, and slide the peice that goes over the axle on and bolt it to the muffler, secure the muffler, and put the peice on that goes to the cat. Anytime you use a car lift for working under a car it's gonna be soooo much easier. I just found it easier to do the installation from muffler to cat.
Hope this helps,
Scott
Hope this helps,
Scott
Car: 1984 Trans Am
Engine: Vortec 355
weld it??
i cant weld it
could i maybe put a clamp or something on it for now and then maybe later have the muffler shop weld it??
i cant weld it
lol, of course u don't have to weld it. Hooker "recomends" it. They'll give you all the clamps you need. You'll reuse your hangers and bolts for the hangers, but for all the connections on the exhaust, you'll have a peice from them in your kit. You'll see.. It's one of the simplest mod's. My advice on removing your old exhaust is just to cut it off. Unbolt where it hangs to the frame, and unbolt the cat conection, then take a sawzall or equivalent and just cut whatever you need to to get the old crap off the car.
Car: 1984 Trans Am
Engine: Vortec 355
haha sweeet
alright man thanks
i'll post my results.......after im doing cruzin for a couple hours
Mods-
K&N Air filter
alright man thanks
Mods-
K&N Air filter
Car: 1984 Trans Am
Engine: Vortec 355
oh hey and something else
how long does it take for the exhaust to break in and sound good?
and can you really feel a diff in performance when you put it on?
Not sure on how long it takes to break in. Mine's only got like 10hours of run time on it and it still sounds great. And, you'll notice the difference, especially over stock exhaust.
Good luck man
Good luck man
Car: 99 Formula
Axle/Gears: 342
Here's a tip on making it stay lookin good. Put chrome polish or wax on the tailpipes before installation, this will make it easier. And every now and then wax or polish them, they will rust.
"Rice burners are like tampons...Every pu$$y has to have one"
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat, just switched to 180* b/c of winter coming and going to college in the mts.
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
3:73 Posi
Rebuilt 700R4
Car: '92 Camaro RS
Engine: 350 H.O.
Axle/Gears: 3.73 posi
You may not have this problem with your Hooker system, but I sure did...one of the pipes coming out of the muffler will NOT line up. I had to get an exhaust shop to fab another pipe for me because it was so off-center. I was really ticked about that, but the end result was great. Everybody talks about a "break-in" period, but my exhaust has sounded the same since day one and that was almost a year ago.
1992 Camaro RS
305 TBI, 5-Speed
K & N open element, Hooker cat-back exhaust,
SplitFire plugs, Moroso Blue Max wires,
Macewen white-face gauge overlays,
Hypertech Power Coil Kit
http://www13.brinkster.com/scbaeb/camaro.html
scbaeb@hotmail.com
1992 Camaro RS
305 TBI, 5-Speed
scbaeb@hotmail.com
Car: 1984 Trans Am
Engine: Vortec 355
wow thanks for the replies!!
i cant wait for it to come!!!!
i just raced this brand new cherokee the other day......maybe i will race him again after the exhaust swap and see if i can see where it helps me the most
and is there any specific type of polish that works best??
thanks for all the help guys!
Mods-
K&N Air filter
Mods-
K&N Air filter
Car: 1984 Trans Am
Engine: Vortec 355
hey i got the exhaust today and after i got off work 10pm i got done fixing the water pump then i started on the exhaust......what could i use to get the rusty bolts off on the cat
and also what would b the best to cut the pipes....i was using the a sawzaw but it was like 1am and i didnt wanna wake the neighbors
and i already used some turtle wax on the tips....is that good enough?
any help would b great
thanks
Mods-
K&N Air filter
thanks
Mods-
K&N Air filter
Actually it's not the tips that rusted on me, it was the rear pipes coming out of the muffler, the tips have been fine so far (about 2 months now) but I did put wax on them. I don't know what else you could do about the rear pipes, it seems like they were made with cheaper metal then the I pipe and actual muffler. I guess thats what you get for a cheap catback kit, I'm actually thinking of getting the rear outlet pipes coated, it looks kinda nasty right now.
Car: 1984 Trans Am
Engine: Vortec 355
well i got it on today
when i FIRST started it up the exhaust was just as quiet as the stock exhaust but then i did some high RPM runs and cruised a lil and now it sounds awesome!
i love the way it cackles and stuff
and i think it improved my performance cuz when i was cruzin i got on it from the start and my tires spun a lil more from the start and they spun when i hit second
and i have new tires now
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by Jono:
Actually it's not the tips that rusted on me, it was the rear pipes coming out of the muffler, the tips have been fine so far (about 2 months now) but I did put wax on them. I don't know what else you could do about the rear pipes, it seems like they were made with cheaper metal then the I pipe and actual muffler. I guess thats what you get for a cheap catback kit, I'm actually thinking of getting the rear outlet pipes coated, it looks kinda nasty right now.</font>
ambainb
Apr 25, 2016 09:21 PM
NinjaNife
Aug 23, 2015 11:49 AM
Hello, Michael
Aug 20, 2015 03:19 PM
