Hedman Headers and Plug Wires
Old Nov 12, 2001 | 11:09 PM
JR4444's Avatar
I have some Hedman headers on the way and I wanted to know if I will have any problems with my spark plugs or wires. I have Bosch Platimum plugs, Taylor 8.0 wires and stock heads. I do have a heat protective boot on each wire. Thanks
88 Formula 350
Upper and Lower SuperRam, 1000 CFM Accel Throttle Body, ZZ4 cam, 24# Motorsport Injectors, Larger Gutted Mass Sensor, Homemade Cold Air induction, Custom Burned PROM, MSD 6a box, MSD Distributor, Accel SuperCoil, Taylor 8mm wires, TB Bypass, B&M shift Kit, 160* Thermostat, Flowmaster Muffler,
Old Nov 13, 2001 | 02:27 AM
Jza's Avatar
Jza
Are those the Spiro-Pros or some other Taylor wires? The Spiro-Pros are good to 600 degrees. Two of my wires are a bare .2 inches from the header tubes and have yet to burn. And that's without any type of protective sleeves. Since you have some, I'd say you should be okay as long as the wire isn't directly touching anything (and they shouldn't anyway). Taylor makes good wire!
[This message has been edited by Jza (edited November 13, 2001).]
Old Nov 13, 2001 | 09:28 AM
VampireHunterC's Avatar
I have Hedman headers on my 84. All of the plug boots clear the headers, except for 2, which are straight boots. The rest are 90 degree boots. The straight boots have yet to burn, but then, I have parked the car until I fix a few things.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
theurge
Aug 21, 2015 12:46 PM
djmarch
Aug 19, 2015 12:07 PM
