Mustang x-pipes
Mustang x-pipes
I know this may seem sacreligous to some of you but can a mustang h- pipe or x pipe setup be used to make a true dual exhaust for our cars
Silly mustang's speed is for F-bodies
u could possibly cut it up into a bunch of peices and maybe makes something out of it but it would make more sense to make one cause the x-pipes wont fit at all
87 IROC-z 305 TPI
Borg Warner T-5 fresh rebuild
10-bolt 3.73 Richmond gears rebuilt GM posi,
formerly BW 9-bolt w/3.45 gears(broke it)
Ported Plenum and Runners Homemade AFPR
ACCEL 8.8 wires, High output coil,and cap & rotor
Bosch platinum + 4 plugs
Ram Air w/ K&N filters,
MAF sensor screens removed, TB coolant bypass
Polyurethane tranny and torque arm mounts
Gutted Cat, Dynomax catback w/custom tips
K&N oil filter,Mobil 1 synth,Factory Oil Cooler, Futura GLS Super Sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
87 IROC-z 305 TPI
Just get a universal x-pipe. Dr. Gas, www.drgas.com (I think) makes them. You can either get just the actual x or the x and the pipes at each end of it. Magnaflow also makes them, but the Dr. Gas design looks a lot better to me, plus look at all the professional racers or race classes that use them (I can't remember which it is).
Also, mac makes sort of an x-pipe substitute. It's basically a hollow box with two inlets on one side and two outlets on the other side. They claim it's good.
I forgot. Do a search on google for "magnaflow mufflers" and for "mac performance". Oh, camaroman85 had a great idea! instead of an x-pipe, use a large dual inlet, dual outlet cat for a crossover--you kill two birds with one stone: extra performance plus it's legal!
I would so do this if I didn't already have my exhaust.
91 formula WS6 305 tpi, T-5, 20,xxx actual miles, Cyclone headers, true dual exhaust, Moroso Blue Max wires
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Here's the link to the post that cort351w is talking about.
https://www.thirdgen.org/messgboard/...ML/003329.html
I'm the one who explained why it would be a good idea.
Seriously, I've always wondered why nobody has thought of it. I was gonna have my local shop do that on mine. I thought I was gonna be one of the few to think of it.
Dang nabbit!!!!! Now the whole country knows!!!!!!
My secret is out!!
AJ
[This message has been edited by AJ_92RS (edited November 16, 2001).]
My secret is out!!
AJ
