Dual exhaust?
Old Nov 26, 2001 | 10:48 PM
19WS6T/A91's Avatar
Dual exhaust?
I would like to run dual exhaust on my 91 t/a. Is it possible to do this and still have enough ground clearence for a daily driver? Anyone who has done this please give me some info. Is it worth the money? What kind of ground clearence will i be looking at? What is the configuration?
1991 Trans Am WS6 with a few bolt ons (flowmaster, air foil, K&N, Taylor 8mm plug wires, trans-go shift kit, and high flow cats)
14.2@97.3 <== i know its not that fast but its my first car and im workin on it. Hoping to eventually get mid 12's out of it.
Old Nov 27, 2001 | 04:13 AM
smnitWS6TA's Avatar
Car: 98 Z28
Engine: 346 LS1
Transmission: 6 spd.
Axle/Gears: Ford 9" 4.11
I've thought about doing this myself many times. I even went to an exhaust shop and asked the guy about it. The problem was that the guy only wanted to run 2" pipes, I wanted 3" and the ground clearance would be very low. Most shops will want to run the pipes straight under the car, this will make ur ground clearance about 2-3" less. I've looked under the car and I think that two pipes could be run side by side in the same curve as the factory pipe and give you the same ground clearance as stock but finding someone to bend the pipes might be a problem. I've found that it's better, and easier to just get a good catback and a big intermediate pipe. If you want more flow you can always put on an exhaust cut-out. Hope this helps.
Old Nov 27, 2001 | 08:44 AM
VampireHunterC's Avatar
I used flex-pipe on my '84. It came with the car. Works pretty well, but not as good-looking as solid pipe. Easier to run, though.
Old Nov 27, 2001 | 10:04 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Do a search here and you will find alot of links, info and pics. of cars with true duals.
Here is one http://home.swipnet.se/pontiacGTA/gtaavgassys.htm
GTA -89:383, 4-bolt,Free flow muffler,dual 3" HF cats, Edelbrock headers, Canfield heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTR, !plenum, 52 TB, MSD 6AL, TPIS level V prom, Superior shift-kit and all the minor mods,looking for a SR ...
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
Camaro_383
Sep 11, 2015 11:28 PM
Djmathis123
Sep 8, 2015 08:42 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
