Borla Exhaust
Old Dec 3, 2001 | 09:50 PM
GetAtMe's Avatar
Borla Exhaust
I bought an 86 Iroc with the borla exhaust system already installed. But i want the car to be loud. to do this my friend suggested either a cut-out, or to replace the muffler with a resonator. i just wanted to see some opinions of which would sound better and if anyone knew how much either of these things would cost. so basically, what would you do if you were me and you wanted a loud car?
'86 Iroc
Borla Exhaust
Other minor modifications
Old Dec 3, 2001 | 10:12 PM
Chris Luongo's Avatar
I briefly look into buying a Borla system....if you have the same system I looked at, there already is an adjustable cutout. I'll try to explain.
BEFORE the muffler, there is a sort of Y-pipe. One leg of the Y goes into the muffler as normal, and the exhaust fumes exit through the left side tailpipe.
On the other leg of the Y, is a direct connection to the passenger side tailpipe, with no muffler. At the place where the tailpipe connects to the Y, it can be unbolted. The kit includes various pieces...... there may be a solid plate in there, or a plate with a small, medium, or large hole. If you replace the plate with one with a larger hole, more exhaust will bypass the muffler, making it louder.
I'd imagine that you could buy the plates from Borla or Summit, or make your own, or enlarge the one already on your car.
Old Dec 3, 2001 | 10:19 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
This is the same borla system I purchased back in 91 or 92. I orginally had it on the 86 Z28 but it now resides in the RS. Look at the pics :
http://www.fototime.com/ftweb/bin/ft...-C5CF34A41E7F}
http://www.fototime.com/ftweb/bin/ft...-ECC0EF86082B}
http://www.fototime.com/ftweb/bin/ft...-D3E1C4CF7509}
[This message has been edited by 86z/92rs (edited December 03, 2001).]
Old Dec 4, 2001 | 02:12 PM
GetAtMe's Avatar
that looks the same, but my exhaust only comes out on one side
Old Dec 5, 2001 | 02:52 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Borla sells a system that is just the muffler and single side exut tail pipes and its not adjustable. Sounds like thats the on you have. I have the adjustble one an its pretty loud.
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Serpentine Setup
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or http://members.cardomain.com/john87iroc
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
Nervous2
Oct 8, 2015 10:53 PM
david068513
Sep 18, 2015 10:36 AM
