Hooker LT Plug Clearance Solution
Old Apr 6, 2003 | 09:40 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Sorry for the delay, just got the pics developed & scanned. This method will work from any plug that has a screw off wire connector. The heads that require this method are AFR 195 straight plug, where there are no shorty plugs made.
I used an agle grinder with a diamond edged tile cutting blade to score the porcelin.
Like so.
Tap end carefully with a hammer to break apart end, so it looks the Accel plug (3rd from the left). Cut metal rod off, just under spacer & grind even with the center electrode rod. I then used a 4mm die to thread the rod & screw the wire connector back on.
86CamaroDan
Sep 29, 2015 10:08 PM
New2Chevy
Sep 28, 2015 12:35 AM
formula_novice
Sep 5, 2015 03:58 AM
gixxer92
Sep 1, 2015 04:32 PM
tricky1
Aug 23, 2015 01:17 PM
