Open headers hut heads?
Old Apr 6, 2003 | 12:39 PM
black85camaro's Avatar
Car: 85 Camaro
Engine: 350 Carbed
Transmission: Stock 700r4
Open headers hurt heads?
Will running open headers to the track hurt anything? I just finished putting the car back togather for the race this Wed and I want to run open headers. Its about a 30 min. drive at 50 mph. It will be about 45-60 degrees out side. They are dynomax shorties that stop at the bottom of the oil pan and point straight down.
-Terry-
P.S. I am looking for that mid 13 time slip!!!
Old Apr 7, 2003 | 05:30 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
no it will not hurt you car. I always run open headers...........
Old Apr 7, 2003 | 10:48 PM
Ian_F's Avatar
Car: 1996 Jeep Cherokee
Engine: 4.0
Transmission: 5 speed
I heard somewhere that if you run with open headers, cold air can go up through the headers whe the car is off and crack the valves. I am pretty sure this is a myth though.
Old Apr 7, 2003 | 11:14 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I believe on shorty headers it could be possible, but unlikely.
Old Apr 9, 2003 | 12:34 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If that was the case there would be a lot of cracked valves at the fall racing events.
evilstuie
Feb 28, 2016 03:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
mdtoren
Aug 23, 2015 12:52 PM
Dialed_In
Aug 20, 2015 01:45 PM
mdtoren
Aug 16, 2015 05:45 PM
