Largest Headers?
Old Apr 8, 2003 | 11:49 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Largest Headers?
What iks the largest header to fit the thirdgens?
Looking for 1 7/8" primaries and 3 1/2" collector if possible.
Hooker makes a set, but I called them yesterday and they said I'd have to run a powerglide, move my engine to the right, and cut into the crossmember. I won't run a powerglide and they don't have any for the 400/350 combination.
Anyone else know of any companies that make headers this size for our cars?
Old Apr 8, 2003 | 12:53 PM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
Why do you need 1 7/8 inch primaries? The Hooker 2210 1 3/4" primaries are adequate for nearly any small block.
Old Apr 8, 2003 | 01:38 PM
Momar's Avatar
Well, if this is going on a motor that runs the times in your sig, I would say dont do it. It will hurt more than help.
If by chance you have something that needs that big of headers(kind of doubtful) then hedman makes some 1 7/8", and some 2" primaried headers. I dont know what the collector is but I believe it is an adjustable race style collector. They are called hedman huslers.
Ben
Old Apr 8, 2003 | 04:56 PM
Ions91Z28's Avatar
Thanks, I'll try giving hedman headers a call. I don't mind doing minor modifications, but having to change by transmission won't help.
The engine I'll be running is the same as a local friend, and coworker. His car recently ran 9.40s in a 3500lb car @ 15lbs of intercooled boost. It's now been swapped to 22lbs of boost, as well as reduced weight. He's expecting 8.80s.
This is the same engine I'll be running except in a lighter car. He's running 1 7/8 headers, so I was trying to find some that I'll need as well.
While 1 3/4 heads are great headers, from what I've read they are pretty good up to around 650 or so horsepower, while his car is probably around 850+ to the rear wheels.
I'm just trying to get some ideas, headers aren't my main concern, was just trying to find out what options I had when the time comes.
Thanks.
Old Apr 8, 2003 | 06:02 PM
Momar's Avatar
What are the specs on this motor? That will be a heck of a change from 14.2's. How is the rest of your car setup, because if it is stock, I could see it tearing its self up real quick. You are going need a built tranny *cough* th400 *cough* and a strong rear end(9" or 12 bolt). I also hope you have subframe connectors and a good suspension.
Ben
Old Apr 8, 2003 | 06:05 PM
Momar's Avatar
I just looked at your website and it does look like you are on a good start for that. Just a question but are all those tpi parts yours down at the bottom? If so WHY?
Ben
Old Apr 8, 2003 | 06:39 PM
Ions91Z28's Avatar
Ben,
Yes, the rearend has alrady been purchased, and next is the spohn TQ arm / Crossmember, turbo 400, new driveshaft, and the rest of the suspension additions.
The engine is 400 with an ATI D1R on it.
Old Apr 8, 2003 | 06:44 PM
Momar's Avatar
What kind of fuel system and heads? Is the motor all forged? What type of rotating assembly?
Ben
Old Apr 8, 2003 | 06:53 PM
Ions91Z28's Avatar
Eagle rotating assembly, with wiseco pistons.
Two aeromotive fuel pumps going to 96lb injectors.
AFR 210 heads.
Old Apr 8, 2003 | 06:57 PM
Momar's Avatar
tpi?
Old Apr 8, 2003 | 06:59 PM
Ions91Z28's Avatar
No single plane converted to EFI with Accel Gen 7 Computer.
Old Apr 8, 2003 | 07:26 PM
Ions91Z28's Avatar
Oh yea,
The TPI parts are all mine, I buy and sell TPI units. Polishing, Powdercoating, and cleaning them up and such. So, those were some that I had on the shelves, just took the picture for fun.
Old Apr 9, 2003 | 09:17 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
A friend of mine runs a 427 EFI smallblock & has the Hooker 2210s on it. BTW, its rated at over 700hp & runs 9.50s all day, NA. His car was on the cover of GMHP last year.
Old Apr 9, 2003 | 09:22 AM
Ions91Z28's Avatar
Ricktpi, If I have to, I may go that route. But I still think there will be more power gained from running the larger header.
Old Apr 9, 2003 | 02:50 PM
Momar's Avatar
Yes, with a 1 3/4 primary you can still make a ton of power, but if you are putting all that money in them I would go with the hedman husler headers and get the bigger primaries. Might as well not waste any power. lol.
Ben
Old Apr 9, 2003 | 09:04 PM
Ions91Z28's Avatar
Ben, I agree. I see no reason to hold back power if I'm looking to buy the headers. If I already had the 2210s, I would go that route.
Old Apr 9, 2003 | 09:46 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I just wanted to say you got one killer setup in the future.
Old Apr 10, 2003 | 12:34 AM
Ions91Z28's Avatar
Thanks mark, just gotta do some saving for a little while.
Old Apr 10, 2003 | 07:32 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I believe Ed Quay makes large headers also. I couldnt tell you how well they fit but..... http://www.edquay.com
Old Apr 10, 2003 | 09:12 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Stahl does, too. http://www.stahlheaders.com
Old Apr 10, 2003 | 10:05 AM
Ricktpi's Avatar
They also say it won't fit stock frame & engine mounts.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
