Keep on blowing header gaskets >=(
Old Apr 17, 2003 | 02:17 AM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
As it says I keep on blowing a header gasket on my passenger side of the car. Ive tried paper gaskets and they blow right away, Ive tried copper but those dont seem to do the job at all. Anyone have any ideas on what I can do to stop this from happening, its driving me nuts my car sounds so good, but that leak is anoying the hell out of me when I keep hearing it!
Old Apr 17, 2003 | 02:30 AM
90Formula-X-F's Avatar
Car: 90 Formula
Engine: 355 C.I.
Transmission: 5 Speed
Since I've gone to Percy's gaskets I've had no problem at all..
They have them at summit. They are a little pricie at 35 bucks but they work... The advertise them like this...
Percy's Seal-4-Good gaskets. Made from "dead soft" aluminum, the Seal-4-Good gaskets are blowproof and reusable.
Worth a try
Old Apr 17, 2003 | 01:26 PM
CAMAROsc350's Avatar
I agree with 90Formula, Percys dead soft aluminum gaskets are the best out there and even though my header bolts have loosened themselves up a few times the gaskets are still perfect, you should definetely pick up a set.
Old Apr 17, 2003 | 01:51 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I solved my leaky flanges with Earl's aluminum with replacable graphite inserts.
Old Apr 17, 2003 | 02:12 PM
fast89RS's Avatar
Car: 1989 Camaro RS
Engine: Vortec 350
Transmission: Built 700R4
Just use some hi-temp silicone to seal it up. Go get the copper stuff, it works great for me.
Old Apr 17, 2003 | 11:19 PM
Mac's Avatar
Mac
Car: 91 RS
Engine: 350 H.O.
Thank you guys for your help I was thinking about the high temp silicon, I think im going to try that and if that doesnt work then the percys.
Old Apr 18, 2003 | 01:58 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
All good ideas - also, if you don't have them, you might consider some Stage 8 locking header bolts. Also not cheap at around $40, but it might help. Good luck.
Old Apr 18, 2003 | 03:35 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
i have had good look with fel pro blues
Old Apr 23, 2003 | 03:14 PM
Knight350's Avatar
I second that, I just installed the 45.00cnd fel pro gaskets and they work great.
BUT..
If you are blowing them that quickly, I know for sure there is a 1 inch thick "crushable" almin. copper core gasket... great for headers with a slight warp. That might be the way to go, but I know they are kinda pricey, they were about 75.00cnd..
Old Apr 23, 2003 | 03:54 PM
james_85Z28's Avatar
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
earl's are the best.
Old Apr 23, 2003 | 05:58 PM
txhotRS's Avatar
Well, I have a different approach, before I installed my headers I shaved the lip of of the inside of all the tubes (the part that goes against the heads )... to make it perfectly flat... then I use regular copper header gaskets... AND LOCK NUTS.. I haven't EVER had a leak, and I've had headers for over 2 years ( I did replace the gasket about 9 months ago, JUST IN GOOD FAITH)
Good Luck
Old May 3, 2003 | 11:53 PM
JLP's Avatar
JLP
Car: 1983 Trans Am
Engine: 305 LG4
When you install the gaskets dont tighten the bolts all the way up.
Cruise around for a bit and get your exhaust nice and hot.
Then tighten them up good.
Might want to try that, thats what I did and it worked well
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Accerrito22
Sep 5, 2015 09:34 PM
90formulaVortec
Sep 3, 2015 09:26 AM
