question about AIR
Old May 11, 2003 | 10:36 PM
89_305TransAm's Avatar
Car: '89 Firebird Trans Am WS6
Engine: 305 TBI (L03)
question about AIR
Someone on another web site i am a member at told me there was a artical about using a belt made for a 96 Plymouth Minivan to delete the air pump pully..searching finds nothing and im a little unclear with the tech artical on this site..anyone know of any good links or anything about the above belt?
Also in the tech artical..it says If you have an underdrive pully you will need Dayco pn# 935K6 which is actually shorter than the stock belt by one inch. ...this didnt come stock on any cars right? its only a aftermarket deal? Thanks for any insight
-joe
Old May 11, 2003 | 11:14 PM
BTS88IROC's Avatar
Thats just a belt size, I'm sure it came on some car at some point in time. Just write that down and take it to autozone or some other auto parts store and they should be able to get you what you need.
Old May 13, 2003 | 02:08 AM
Dan88IrocZ's Avatar
Just take a string and route it around your entire pully set up and then measure it. Give the length to the counter junkies & they will find you one in the right length.
Old May 13, 2003 | 09:22 AM
MdFormula350's Avatar
when i deleted the air pump on my car i had to get a bigger belt, i believe it was like 2 inches bigger.
my belt routing goes as follows.
over the a/c pulley, under the idler pulley, over the alternator, under the power steering, over the water pump, under the crank and back to the over the a/c pulley.
my stock routing before i deleted the a/c was:
over the a/c, under the ilder, over the alternator, under the power steering, under the crank, over the water pump,under the smog pump and back over the a/c pump.
if your car is stock then underdrive pullies dont apply.
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
wruiz
Aug 13, 2015 09:07 PM
