What in the heck kinda flange and donut gaskets for T.E.S headers?
Car: 88 Z28
Engine: 408 Small Block
Transmission: TH350
Axle/Gears: 9" w/ 3.90's
What size gaskets to these require?
Also....Will the headers only accept a normal exhaust flange?
IE: bending out a custom y-pipe to connect to them.
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
I used a GM# 15634536 packing with no problem. It is used on some older 70's GM trucks. Some shops can make that flange. It requires a flare & a smaller 2-1/2" OD pipe welded or pressed inside to hold the donut.
Breazlan
Sep 25, 2015 11:20 AM
