Best Headers Money Can Buy?
Sounds to me like quite a few people on those threads had them fit fine with no problems. It just seems to be the people that havent really done to much in depth work before and dont know how to work out problems when you run into them. Most of these problems are not serious, and some are just simply someone that hasnt done it before and got stuck on something.
Ben
Ben
I guess everyone else who knows about the poor fitment of the SLP's are smoking something too right? I was trying to help someone who asked for it make the right choice on what headers to get. If he wants to spend outragous amounts of money on headers that not only fit poorly, but dont make more power than the hookers, which do fit right, then by all means go for it. If you are happy with your SLP's then great, but plenty of other people aren't. Here is some info on the 2055's.
https://www.thirdgen.org/techbb2/sho...ker+super+comp
https://www.thirdgen.org/techbb2/sho...ht=hooker+2055
If you actually read through those posts you posted, it appears that more people have had them fit fine than not. The only thing that seems to be fairly common is hitting the steering shaft which is easily fixed by moving over the steering shaft.
Ben
Ben
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
Some folks choose headers because of things like ground clearance and to avoid huge money expenditures on custom Y-pipes too
.... (get yourself a T56 with the appropriate tranny crossmember and figure out a Y-pipe for long tubes that doesn't get real friendly with the pavement and get back to me....)
And Momar is right on with the collector.... It's called a merge-collector and it is designed to aid in scavenging. Lots of headers do this. From what I have seen most of us here have nothing to worry about when it comes to choking off flow - even if they are 2 1/4" .....
And it isn't always the aftermarket part manufacturer's fault when it comes to improper fitment..... Our cars are mass-produced... No two are really alike
All that being said, I would much rather have a 1 3/4" long tube on my car (especially with the new 383 about to go in)..... And I have gone round and round with SLP in the past before too... But they have gotten better recently (IMO) and I don't let that decide what part I bolt on my car.
my $.02
.... (get yourself a T56 with the appropriate tranny crossmember and figure out a Y-pipe for long tubes that doesn't get real friendly with the pavement and get back to me....)And Momar is right on with the collector.... It's called a merge-collector and it is designed to aid in scavenging. Lots of headers do this. From what I have seen most of us here have nothing to worry about when it comes to choking off flow - even if they are 2 1/4" .....
.All that being said, I would much rather have a 1 3/4" long tube on my car (especially with the new 383 about to go in)..... And I have gone round and round with SLP in the past before too... But they have gotten better recently (IMO) and I don't let that decide what part I bolt on my car.
my $.02
my $.02
my $.02
Car: `86 SS / `87 SS
Originally posted by 25THRSS
Just because SLP recommends that doesnt mean it's right. SLP products are crap and their service is even more crap in my opinion. You not only have to spend the outragous amount of money on the inferior SLP's, you also have to buy their install kit and even further get ripped off by having to buy a cat adaptor as well. If you like modifying steering shafts and haveing exhaust pipes stick out into the wheel well and possibly melt part of your car, and getting ripped off in the process, then by all means buy SLP. It's your opinion. To anyone else that is willing to listen, the Hooker 2055's are far, far better. They have 1 5/8 primaries, which are good for anything will less than 400 hp, 3 inch collectors, 2.5 inch piping into a 3 inch collector, and best of all they have no fitment issues what so ever and are 50 state smog legal if you care about that. Everything you need comes with the Hookers. Another thing to realize is if your motor requires the use of 1 3/4 primaries then 2 1/4 exhaust just aint gonna cut it.
But really, what good are the gaskets and bolts that come with the Hookers? It's called stage 8's and doubled up Fel-Pros, paper to paper. CTandC taught me that last one. No leaks.
Matthew
Matthew
Matthew
Ben
Car: '85 Z28
Transmission: WC T5, 3.23 posi
I had to file the locks down on my Stage 8 bolts so that they would fit next to some of the primaries. Never had a leak so far and I've had them for over a year.
Originally posted by Momar
thinking about trying to grind away a little material on the stage 8 locks so that they will fit with my larger primaries.
That's what I had to do on some Hookers with 1 & 5/8" primaries. Good thing I did them at a friends house w/ a bench grinder
-Matthew
More thoughts......
I agree totally with everything you just said, but where did anyone even mention anything about merge collectors? I only recall talking about the collectors on the 2055's and they are not merge collectors. Hooker claims they are that size to assure a good seal. It has nothing to do with scavenging. Lots of headers do not do this. I am only aware of 1 company that currently offers massed produced merge collectors on the market and that is dynatech. That being said, SLP headers are nice headers, but they are not the best by any means. There are plenty of shortly headers out there that are far inferior to the SLP's.
Why dont you just save the trouble all together if you are purely worried about performance and go with long tubes.
The bottom line is nobody says "Well, given the choice of running a 3" Y-pipe and a 2 1/4" Y-pipe, I will go with the 2 1/4" one"..... What I am saying, is that some of us have NO choice sometimes. Whether that be purely for fitment or clearance issues or funding AND fitment or clearance issues, etc., isn't really the point... Eventually I will have 1 3/4" long tubes on my car and have them and/or the Y-pipe made to meet my needs.... But we can't all have everything the way we want it to be when we want it to be that way... Or at least I can't
. Re: More thoughts......
I am talking about the SLPs with the merge-collector business, not the Hookers... There was talk about the small size of the collectors on the SLPs and I was providing the info on why that is not really a concern. Ideally the Y-pipe should open back up to 3" a bit after that merge-collector and that is where the SLPs as a kit will hinder some flow... But either way the 1 3/4" SLPs will support more power than the 1 5/8" Hookers.... And I have yet to get my hands on a 1 3/4" SLP-equipped car where they don't fit. Yes, it might have required a little inginuity at times, but c'mon.... If you're going to play the game...... etc etc. If you want ones that install themselves, shift the sacrifice to power and get the TES.... And I have to reference my comment above about our cars being mass-produced for the extreme cases with the SLP's fitment and that we are human for the cases where something is actually improperly manufactured and they won't fit at all.
Trouble? What trouble? But to answer the question: Because I am not just worried about performance.... I am looking to get the best performance I can with my combo without paying out my a$$ to have a custom Y-pipe made.... Or more accurately, have my front subframes notched AND have a custom Y-pipe made..... I'll just stick with the SLP 1 3/4" ones for now.... And yes I will be making enough power to need as much exhaust flow as I can get (383, Miniram, ZZX, ported TFS heads, etc. etc.).
Anyway, I guess I will see if I can get the locks on my staqe 8 bolts to fit with some grinding in a couple of weeks when I do my head + intake swap.
Ben
evilstuie
Feb 28, 2016 03:33 PM
hectre13
Sep 8, 2015 03:38 PM
hectre13
Aug 26, 2015 08:17 AM
