what mods if any to put truck headers in 92 3rd gen?
Old Jun 1, 2003 | 05:39 PM
25thanniversZ's Avatar
I got the tools to do whatever I need to, but what do I need to do to put 72 headman truck headers on my 92 camaro???Im to broke at the moment to buy 3rd gen headers cause I just put a pair on my other 3rd gen, but I have a brand new set for my 72 gmc truck that I cant use at the moment because I robbed the tranny out of it to put in my 92 camaro which worked out nicely
Old Jun 1, 2003 | 10:56 PM
anybody got a suave answer?
Old Jun 2, 2003 | 06:33 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Sell the truck headers & buy the right ones. Other than that a massive amount of cutting, fitting & welding.
Old Jun 2, 2003 | 11:20 PM
so basicaly no.......completly impossible huh?exactly what kind of cutting and welding?
Old Jun 3, 2003 | 01:00 PM
Ricktpi's Avatar
Not impossible, but definitely not worth the time & trouble. If you have never built a weld together header, I wouldn't reccomend it, useless you have a lot of patience & time on your hands, not to mention the possibilty of having in the end a piece of scrap metal you cant use.
Old Jun 3, 2003 | 01:51 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well if you want a Suave answer. It is possible they could work. I fited my 76 PU manifolds into the firebird just to see and guess what? With a custom y pipe they would have worked! Now remebering how I put the headers in the truck originally they almost slide right into position except I had to take the spark plugs out. Funny because the BB headers were a PITA to install and involved raising the engine. Ifyou got the spare time try it, cant hurt much although the truck headers are a bit longer from the flange to collector.
Old Jun 3, 2003 | 06:56 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The truck header will most likely just go in w/o any problems. '72 truck headers (long tube, blackjack) hug the engine closer than fbody headers and also sweep back towards the firewall better to clear the engine mount braces, engine x-member and lower control arm. I can tell you that fbody shorties however, do not fit a 72 truck worth a damm. They hit the motor mount brace on on the drivers side and the frame on the other.
Old Jun 4, 2003 | 12:01 AM
thanks...i'll give it a try....hell if they dont oh well, need to change my gaskets anyway
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sreZ28
Aug 14, 2015 07:48 PM
reiderz iroc
Aug 13, 2015 04:57 PM
squiggy2
Aug 9, 2015 09:30 PM
