Sound/movie clip of Hooker exhaust
Just got a Dazzle and decided to give it a try:
Link to video
I got several more of me racing myself and others. I'll post those when I get more time...
Link to video
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
what are the specs on the cam ?
Spectre - I don't know
The Jasper engineer said it's a "torque cam" around .420" lift and only between 204* and 210* duration on a 112 LSA. He said all the Class 1 cams are slightly different, but most fall in that range. Seeing that power falls off pretty sharp around 4800-5000RPM I'd say that's about right.
bigalsz28 - I had to work Saturday to at least 12. I'd lose my job if I called in sick. I was checking up on the weather the whole time at work. Then it really let loose around here. I've got about 0/32 tread on my Nitto DR's so I didn't want to chance it...
The Jasper engineer said it's a "torque cam" around .420" lift and only between 204* and 210* duration on a 112 LSA. He said all the Class 1 cams are slightly different, but most fall in that range. Seeing that power falls off pretty sharp around 4800-5000RPM I'd say that's about right.bigalsz28 - I had to work Saturday to at least 12. I'd lose my job if I called in sick. I was checking up on the weather the whole time at work. Then it really let loose around here. I've got about 0/32 tread on my Nitto DR's so I didn't want to chance it...
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
