Need Info on Headers
Old Jul 20, 2003 | 06:28 PM
Jose'sRedTA's Avatar
Car: 87' Red TA w/ 92k miles
Alright guys, I've done a search already and cannot seem to get a real idea of what I need. I have a stock 305 TPI in my 87' Trans Am. I just recently installed a Flowmaster series 80 muffler and new 2 1/2 inch pipes. I know nothing about installing headers and will most likely have a mechanic do it, but I need to know what are the easiest fitting headers on the market...i.e. little or no tampering with AC, etc...and try to do no grinding on parts. Basically I haven't got a clue about this stuff and would greatly appreciate it if someone could provide me with some straight info. Also whats the deal with coated and uncoated, besides about 300 bucks...does it really make a difference? I'm looking to spend no more then 250 to 300 bucks, maybe can splurge for more. Please advise...i'm new to this forum and all of you:hail: experienced:hail: folks out there have a wealth of info and wisdom, so any and all help is appreciated...Thanks ahead!
Old Jul 21, 2003 | 01:42 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Re: Need Info on Headers
Its not really a hard job, just very time consuming depending on your mechanical skill.
There will be some fabrication necassary on any header installation. Rather than messing with the A/C, I just took it out. You should be able to do the same relatively easy since you have an '87. There is no "perfect fit" set that will be easiest. I would stay away from 1 3/4" headers if you are just running an otherwise stock motor.
You should also check the search option. You can search through the Exhaust forum and get all of the answers you'll need.
Probably about right.... although, for the money, that may or may not include a Y-pipe which you'll need.
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
