converting dual cats to a single catalytic converter
Old Jul 22, 2003 | 01:04 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I'm planning to convert my dual cat to a single cat. I have edelbrock header part # 6876, for dual cat camaros. Will the y-pipe from header part #6872 3" slip fit cat, fit on the dual cat header; and yes I will change the I-pipe.
I've been running 13.8 in the 1/4 for a while, but I've been recently burnning the catalytic converters out. My friends and I can't find the problem. I need something to hold me over untill an engine swap in the future. I going through a catalytic converter every 7 months.
Old Jul 22, 2003 | 10:24 PM
KYL98's Avatar
Car: 1991 Z28
Check your A.I.R pump, mine did that and turned out to be a faulty diverter valve.....are the cats clogging? Check 02 sensor, leaky fuel injectors. Also....bad valve seals will clog one in a hurry.....Id check all that stuff first....good luck
Hotrodboba400
Dec 10, 2019 07:07 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
