Problems with my Edelbrock T.E.S.
Old Jul 24, 2003 | 09:28 PM
PsychoGTA's Avatar
Did you guys ever had this problem? I guess after a while of the headers rubbing on to the alumin pipe that comes from the radiator to the engine i think it is. It started leaking and I was wondering If you guys can give me a solution to this problem. I was thinking of putting new engine mounts to lift up the headers. What do u you guys think? I'll post a pic tomorrow, to show you what i'm talking about.
Thanx,
PsychoGTA:lala:
Old Jul 24, 2003 | 09:41 PM
llvll4l2c91350's Avatar
im guessing you're talkin about the tranny cooler lines. i have the same headers but haven't had any problems since the installation. i haven't been under the car in a while so i dont know where exactly they can hit.
Old Jul 25, 2003 | 08:28 PM
BlackBeast'88's Avatar
Car: '88 Formula
Engine: 355cid
Yeah I haven't had any problems with these headers either. I just sent mine off to get jet hot coated.
Old Jul 25, 2003 | 09:02 PM
87camarodan's Avatar
my TESs
I havent had any problems with mine yet... but I think the reason is that they are sitting on the floor awaiting some paint and waiting for the old exhaust manifolds to get out of their way.
any advice on getting the last bolts out of there? those guys are really nasty. all the way in the back
Old Jul 25, 2003 | 11:52 PM
make sure you use a lot of penetrating oil. my A/C and smog stuff was out at the time so i had a lot of room to work with.
Old Jul 29, 2003 | 03:41 PM
PsychoGTA's Avatar
pics of my problem
What do u guys think I can do?
Old Jul 29, 2003 | 03:45 PM
PsychoGTA's Avatar
pic 2
Old Jul 29, 2003 | 04:08 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
I haven't had any clearance issues other that the bonehead ones I hit when I got the collector flanges turned the wrong way and they hit the crossmember. It looks like the problem you are having is with the ENGINE oil cooler lines. I've attached a pic of mine for your reference, but I don't know how much help it'll be. It looks like your lines are routed different than mine, but maybe not. Could you post a broader pic of the area, and also one from the bottom?
Old Jul 29, 2003 | 04:30 PM
PsychoGTA's Avatar
under car
Old Jul 29, 2003 | 04:33 PM
PsychoGTA's Avatar
another
Old Jul 29, 2003 | 04:35 PM
PsychoGTA's Avatar
and another
Old Jul 29, 2003 | 04:39 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Looks like you are going to have to do a little re-routing work on those coolant lines. I'd take that header off, and get them tucked tight to the oil pan, and then put the header back in. Make sure when you do, that you get the flange in the optimal position for clearance, that may take a couple tries to get right.
theshackle
Sep 17, 2020 08:26 AM
Ducati900ss
Sep 2, 2015 09:05 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
86IROC112
Aug 17, 2015 02:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
