Can't Pass MD Emissions!!!
Old Aug 9, 2003 | 08:07 PM
BlackBeast'88's Avatar
Car: '88 Formula
Engine: 355cid
That's right I can't get thru the MD emissions test! I have put in new injectors, new CAT. Everything on my car is 50 state legal. The only thing I can think of is that I have a bad EGR value or something. Not sure what's going on. The only potion of the test that I can pass is the cat converter part. Help me out here guys. Here's what I have.
88 Formula TPI 350 bored .30 over.
edelbrock headers jet hot coated.
big mouth manifold
flowmaster exhaust
24lb injectors
WC T-5
custom prom--hasn't been burned for new injectors
Old Aug 9, 2003 | 08:33 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
it would help if you told us which emissions you are failing for and by how much
Old Aug 9, 2003 | 09:07 PM
Car: '88 Formula
Engine: 355cid
I'm failing everything except the cat portion of the emission. And I'm within 10-20% of passing.
Old Aug 10, 2003 | 12:30 AM
Anjiru's Avatar
wow man sorry to hear that I dont know nothing about Emissions control cuz where I live all you need is like 20$ and the cars liscence and they pass you some place Highly illegal tho but hey if you find a place you dont even need to bring the car. lol Smog pump what smog pump!??:lala:
Old Aug 10, 2003 | 01:47 AM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Could you tell us what you failed, and by how much?
Have you done a normal tune-up? Spark plugs, wires, ignition coil and cap, and fuel filter?
It's good maintenance, and it maybe that one of those components isn't functioning right, or optimally, and causing the problem.
Old Aug 10, 2003 | 09:21 AM
Car: '88 Formula
Engine: 355cid
Everything is new as I just had new injectors, new fuel pump, fuel filter, new bigmouth manifold, wires plugs etc. Practically a new engine.
Old Aug 10, 2003 | 10:45 AM
Christos's Avatar
What did you set your base timing to? If you advanced it, it could be part of the problem. You might want to try setting it to 6* or so, which is stock at least on an 86 305 tpi.
Nice engine it sounds like! Since you don't have a chip burnt for the new injectors, wouldn't that make you run too rich?
Old Aug 10, 2003 | 11:23 AM
Car: '88 Formula
Engine: 355cid
Thanks dude. I"m not sure whether or not a new chip would resolve this problem. I think the ECM automatically adjusts for the new fuel pressure....I just want it to run like a roadrunner.
Old Aug 10, 2003 | 11:31 AM
Christos's Avatar
I bet! : )
No, from what I recall, your ecm controls the injector pulse width, and if it assumes you have stock 22lb injectors, it will be running the new #24lb's at the same duty cycle.
With the O2 sensor, the ecm will adjust things to keep the air/fuel as right as it can.
You might want to jump in the ECM, or PROM board, and ask somebody there about emissions, and your current LB injectors with a stock ecm, and if that might be a factor in why you aren't able to pass.
Fuel pressure is controlled by a fuel pressure regulator, not the ecm. The ecm just tells the injectors when to fire, and for how long.
Old Aug 10, 2003 | 05:21 PM
Car: '88 Formula
Engine: 355cid
Thanks Chris I will do that...but keep the ideas coming as someone out there might have had the same problem....
Old Aug 10, 2003 | 08:42 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
What temperature is your car running at? If you have modded it to run cooler, that may be why you can't pass the test.
Remember, GM runs our cars real hot, like 220-230, just to pass emissions. Just thought I would throw that out there.
Also, I would be getting into that PROM real quick, if you changed the size of your injectors. Christos said it all correctly.
Or you could find a car that does pass emissons, and just plug in your car info so you can get the sticker. I don't think the sniffer pipe cares whose car its up!
Old Aug 11, 2003 | 02:20 PM
Car: '88 Formula
Engine: 355cid
MikeT 88IROC350 the car is running pretty cold these days with the jet hot coated headers and new radiator. The temps are around 170-180 so you could be on to something. I do have to get the chip burned sooner rather than later. Thanks for info....keep the ideas coming.
P.S. I wish the guys at the emission shop would have took care of me but they didn't make if I slip them a 20 or a 6 pack of beer they would do it.
Old Aug 11, 2003 | 03:18 PM
Christos's Avatar
I've heard that a lot from people, but none who back it up by saying they did it. It's always a friend of a friend sort of thing... Like hearing how a friend of a friend won a million dollars in vegas. Doesn't mean you will.
From a business perspective, they would be breaking federal law to do that, and the business would be shut down. I'm sure the owner has had lengthily talks with employees about just that, and also probably made them sign something stating they are solely at fault if they get caught breaking that law, to push as much blame away from the business as they can if it happens. I'm sure it does, but not as often as most people think.
Cool, get a chip burnt for those injectors, toss in a 190 degree thermostat (I think it's agreed that GM went a bit TOO hot on our cars, all newer cars that I see run 190*) and back your base timing to stock. Hopefully that will get you a passing grade!
Old Aug 11, 2003 | 05:54 PM
Car: '88 Formula
Engine: 355cid
You're right dude....I'd rather pass the old fashion way.....by truly earning the right.....now on to the chip burning.
Old Aug 14, 2003 | 03:57 PM
Marc 85Z28's Avatar
You need to post the test results. I assume the NOx is too high? Do you have a manual fan switch? If so I'd turn the fans off during the test. Get that temp up to the 220 mark and you should be OK.
If my car passed with a larger engine than stock with the factory carb and NO cat then something is quite wrong.
Old Aug 20, 2003 | 08:39 AM
Car: '88 Formula
Engine: 355cid
I'll post the results in a bit. I don't have a manual fan switch and now my car runs around 160-170 degrees...
Old Aug 20, 2003 | 06:18 PM
Car: '88 Formula
Engine: 355cid
Okay here are the numbers
Hydrocarbons
Standard 1.7000GPM
My results were 27.3484GPM
Carbon Monoxide
Standard 30.0000GPM
My results were 137.4027GPM
NoX
Standard 2.7000GPM
My results were 2.7797GPM
So what do you think??
Old Aug 20, 2003 | 06:38 PM
Christos's Avatar
These are with your original prom right?
Old Aug 20, 2003 | 06:45 PM
Christos's Avatar
http://www.type2.com/library/exhaust/comix.htm
Old Aug 20, 2003 | 06:59 PM
Car: '88 Formula
Engine: 355cid
Yeah it a custom PROM I had burned years ago......I think I need..no I KNOW I need something else burned.
Old Aug 21, 2003 | 12:03 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Here's what I learned from California's emissions test:
High HC levels are from an uneven air fuel ratio.
High CO levels are from a lack of Air entering the engine.
High NOX levels are due to High combustion temperatures.
Also, after emailing the California Air Resource Board, they told me that 50 state legal Aftermarket parts are tested, approved and certified to only work with the rest of the Stock engine components.
In other words 50 state legal aftermarket parts are not designed or approved to work in conjunction with other aftermarket parts 50 state legal or not. Hope this helps.
Old Aug 21, 2003 | 12:12 PM
Christos's Avatar
Those are some good tips there!
I passed Cali emissions somehow myself. I had my cat replaced, new plugs, wires, coolant temp sensor, timing set to stock (6* advance) and also had my fuel injectors cleaned.
I will look for my sheet, but I had 0 c02, I remember that. I was running a bit lean too oddly.
Old Aug 21, 2003 | 05:41 PM
2 dope's Avatar
Car: 1985 Camaro Z 28
Engine: 305 LG4
heres a link that may be of interest for those requiring e-test
https://www.thirdgen.org/techbb2/sho...hreadid=194191
Old Aug 21, 2003 | 06:32 PM
Car: '88 Formula
Engine: 355cid
Thanks guys I'll keep you posted. I did receive a waiver because I had sooooo much work done to the car....I'll have to get tested again next year if I'm not in the desert by then.....
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
