How do i remove the steering shaft so i can drop in my headers?
Old Aug 20, 2003 | 01:29 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
How do i remove my steering shaft so i can put in my hedman headers?
Old Aug 20, 2003 | 02:05 PM
posbird87's Avatar
Car: 87 formie
Engine: none
Transmission: none
are these long tubes or shortys?
i put shortys on my 350, no need to remove the steering shaft at all. we just tilted the engine back a tad and work em in there
Old Aug 20, 2003 | 03:57 PM
RICHRAD's Avatar
one the inside firewall there is 3 support bolts at the column behind the firewall pad...take 'em out. Also 2 sliding adjustable bolts at the dash and column.....loosen those.... column should swing over considerably.....you might have to bend your brakelines out of the way
Old Aug 20, 2003 | 05:01 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Remove the through bolt on the driver side motor mount (11/16 and 5/8 wrenches); then using a jack, put a block of wood between it and the oil pan and raise the engine up 1 or 2 inches...much easier than messing with 3 or 4 bolts, 2 nuts, and a bunch of screws...
Pete
Old Aug 20, 2003 | 05:32 PM
tbfirebird's Avatar
Engine: ??????????
actually i just took off 1 bolt a 1 nut right by the brake master cyclinder and it was enough.
thanks anyways.:hail:
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
Bull86
Aug 10, 2015 05:43 PM
3rdgenparts
Aug 8, 2015 07:09 PM
