more power with a muffler?
hey, i just finished my exhaust on my 92 305 tbi. i installed hedman elites with a custom 3" y pipe a high flow catco cat and a 3" I pipe. the aero chamber muffler i ordered is on back order so i had the shop stop the I pipe where the muffler would sit., so for now its just an open 3" I pipe. i took the car out last night and the power was pretty nice, im not sure if its just me, but i expected more low end torque. what i was wondering is, am i losing torque due to a not enough back pressureissue? when i put the muffler on will i see even more improvements? let me know. thanks.
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
You are basically running your car with like the cut-out open. When my car was a 305 I ran it all the time with the cut-out open. Sound wasn't that bad, in fact it was probably a little quieter than my current engine with the cut-out closed. You will make more power with the muffler off due to the less restriction in the exhaust. The cat should be creating backpressure anyway so no worries about that. The only thing I can see problems with it is if Mr. Law pulls you over for no muffler. You won't really notice that much of a difference with the muffler on other than sound level wise.
Probably just felt like that because the car was quieter. Gave the illusion the car wasn't trying. With the open exhaust it seems you are going at it because of how loud it is.
actually, the car was just as loud before hand because the I pipe was like slightly rotted through, so you heard it under the car.. anyway, thanks guys, well see what happenes with that muffler.. does anyone suggest not using a muffler and just running two end tips?
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
noobs
we are back to this huh
backpressure doesn't create torque
if you think so you might want to read up on the subject or be able to explain why it creates torque before you talk about it
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
The seat dyno can be decieving, I can assure you the car makes no more power with the addition of a muffler. It makes no sense to assume the engine will perform better with increased pumping losses due to a more restrictive exhaust...
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by 92 z28
dam, i was hoping i was losing torque due to not enough back pressure. whem i had my stock exhaust i think it was more powerful on the lower rpms.
put it this way, when i had open headers i had no power, when i had the y pipe cat and opened I pipe i had nice power, once i put the muffler on i felt a loss in power. i think im going to put a cut out before the muffler, what do you say?
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
just look at your engine as an "air pump" the better it can suck air in and the faster it can get rid of it.....The more power it makes, period, end of sentence, Game..set..match,
btw, howd you get on probation?
sailtexas186548
Aug 24, 2015 10:11 PM
