Lt1 Exhaust Help!
Old Sep 21, 2003 | 01:13 AM
90formula5spd's Avatar
Car: 1989 trans am
Engine: 357sbc
Lt1 Exhaust Help!
WHAT WOULD THE BEST EXHAUST SYSTEM (INCLUDING HEADERS) BE FOR A LT1 INA 3RD GEN? NEONE HAD EXP. NEONE KNO? PLZ HELP ME OUT HERE! THANX!
Old Sep 21, 2003 | 10:08 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
an lt1 has traditional exhaust ports right? so any of the aftermarket exhaust components for 3rd gens should bolt right up.
Old Sep 21, 2003 | 12:02 PM
speedingpenguin's Avatar
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
i thought LS1's were like 0 0 0 0
and thirdgens and earlier were like 0 00 0?
i could be mistaken, but ya might wanna search around for that answer. look in the motor swap section, i think they have a sticky about lt1s and crap
Old Sep 21, 2003 | 02:00 PM
Falconiroc's Avatar
Car: 1991 RS
Axle/Gears: 4.11
yes LS1s look like 0 0 0 0
LT-1s look like 0 00 0 just like traditional Gen 1 blocks.. and yes they wll bolt right up with thirdgen headers.
Old Sep 21, 2003 | 02:18 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
of the 2 LT1 swaps ive seen in real life, both had SLP 3rdgen headers with custom Y pipes.
Old Sep 21, 2003 | 03:28 PM
mw66nova's Avatar
Engine: 7.0L
i say go longtubes with whatever you decided. they are so much nicer.
Old Sep 21, 2003 | 06:24 PM
Car: 1989 trans am
Engine: 357sbc
thanx alot that is very helpful now what brands r the most hp generous?
Old Sep 21, 2003 | 07:51 PM
oh. sry then....i thought that the 0 00 0 ones were for anything before LT1 but yeah sry again....was close though, was close ;-)
Old Sep 21, 2003 | 08:58 PM
Car: 1989 trans am
Engine: 357sbc
not a prob man thanx for the reply!
Old Sep 22, 2003 | 12:47 AM
mw66nova's Avatar
Engine: 7.0L
hooker is probably the best longtube header, but i am running the hedman hedders longtube header and like them very much.
Old Oct 7, 2003 | 04:22 PM
Car: 1989 trans am
Engine: 357sbc
Ok I want REAL dual exhaust none of that fake ****, two pipes right off the headers, there is not emissions in minnesota and thats where i would get the most HP right? I was also thinking about side pipes, could i do those on my caR?
Old Oct 7, 2003 | 07:29 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
A single 3" exhaust outflows most true dual set-ups. A dual set-up sounds much better but causes a lot of clearance problems with these cars. I nice set of 1 3/4" shorties with a 3" y pipe cat and catback will be more than enough to support a healthy LT1. Yes longtubes are ideal, but for 10hp less I would want the ground clearance to complment a low suspension set-up. There are many fourth gen heads and cammed LT1's running shorties with 1 5/8 primaries putting down 350+ to the wheels. Just buy any system that is desing for a thirdgen and it will work with an LT1. Now LS1's are completely different and require the retention of the stock manifolds or custom headers with a tubular k-member.
Old Oct 7, 2003 | 08:41 PM
Car: 1989 trans am
Engine: 357sbc
My goal HP is around 500, will that system be ok at 500+ hp? It isn't like im gunna have 500 tomorrow or even this year but eventually, and i see no reason to go with something that will work for now but i will have to replace for later, neway thanx for the reply, gimme more!
L0tuS
Oct 4, 2015 08:07 AM
customblackbird
Oct 1, 2015 04:30 PM
New2Chevy
Sep 28, 2015 12:35 AM
Djmathis123
Sep 8, 2015 08:42 PM
L0tuS
Sep 4, 2015 11:16 PM
