SLP header bolts
Old Sep 25, 2003 | 11:28 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
SLP header bolts
Did any of you guys with SLP headers have problems getting all of the bolts tightented, I've got three that I can get screwed in but because of the flange I cant get a tool around them, ideas? Also I have leaks from the collectors where they mate to the y-pipe, again ideas? Thanks.
Old Sep 26, 2003 | 12:52 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Here's what I did. I took a box wrench and ground down around the outside of it. Then I could tighten the last few loose ones.
Old Sep 26, 2003 | 06:09 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
It's dremel time, thanks man I didn't think of that. Anyone have ideas on the leaks?
Old Sep 27, 2003 | 10:59 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
Make sure your Y-pipe is lined up with the collectors as well as you can get them, and tighten it enough to crush the doughnut gasket all the way around. That's all I did.
Old Oct 1, 2003 | 03:39 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hey there Brian...
My SLPs still leak at the moment too, but I just got the Borla today so it looks like I'll be ripping the whole system out to reinstall the headers and the exhaust at the same time.
Ed
Old Oct 1, 2003 | 09:26 AM
MdFormula350's Avatar
I slapped mine on, i have leaks i am pretty sure also, do i care NO
well i care but i dont have time sitting on the ground again fixing stuff, my garage is full of crap again.
Old Oct 1, 2003 | 02:10 PM
91RS5speed's Avatar
Car: 91 RS
Axle/Gears: Auburn Pro / 3.42
I had problems getting mine started also. Just dont tighten one down before you have the others in and also tighten them down evenly. I used gasgets from napa and I have had no leaks. I was able to tighten a couple of the bolts alittle more after a week but they havnt moved since then.
I got the install kit from slp but they didnt come with gasgets was is supose too?
Old Oct 1, 2003 | 02:20 PM
yeah my kit came with gaskets, i got the non air install kit, it was like 45 bucks
Old Oct 1, 2003 | 02:52 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
It's like a reunion from the GP :lala: ..... lol.
I used Felpro 1404 header gaskets, some generic brand small hex-headed header bolts, generic grade 8 collector bolts, and some generic donuts from Checker that fit the collectors..... Buying through my other sources saved me some decent $$$$$ over the SLP kit... Plus I plain won't run anything but the 1404 or 1406 Felpros for header gaskets. Been there and back with mine and friends' cars and they have proven themselves many, many times over .
Anyways, I had a problem with mine when I first got them too. The driver side header had a warped flange for #3 and #5 and flat-out would NOT seal. No way, no how.... In fact I tried so hard I ended up having to helicoil those bolt holes . Ooops. Well I sent it back as they said they would not do anything warranty-wise until they saw the header and passed judgement on its condition. Well they took one look at it and sent me a new header and all was well with that one. I did have to do some argueing to get them to cover shipping though..... typical SLP there.
I have an extensive set of Snap On tools from when I was a tech and I don't really have a problem getting the 7/16" combination wrench onto the bolts I use. I run the box end as long as possible and then even use the open end a little where necessary. I also can get the 1/4 drive socket on some of them. I think the precision of how the tool is built will be a factor here.
As for the Y-pipe, I did what others said with respect to tightening it down slowly and evenly until the donut crushes all the way around.
No leaks for me
Old Oct 1, 2003 | 08:13 PM
LastViceRS's Avatar
Car: '91 RS
Hey Ed,
I guess I have been fortunate with my SLPs - I haven't had the first leak, except for when the pass-side Y-pipe bolts backed out a few turns. Of course I had to be 400 miles from home when it happened, at least I had the right tools. That was a couple of months after installing them. Since then, no problems.
:lala:
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
hectre13
Sep 8, 2015 03:38 PM
Thirdgen89GTA
Aug 20, 2015 12:11 PM
