Finished Hedman Install
Old Mar 30, 2003 | 09:46 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
Well, the head swap is almost done, just got to start it up and put exhaust on. Didn't want to start it with open headers, in case the rockers needed more adjusting.
These headers were a pain in the azz. All emissions previously removed and no AC and no AC/heater box.
Passenger side, had to remove the starter and went in ok.
Driver side, had to take off the oil filter, and hack a small chunk away from the A-arm
Had to dent a header tube in order for a spark plug to clear.
Putting plugs in was a joke too.
Weds, I will be finishing he exhaust install and crankin her up
Old Mar 31, 2003 | 10:26 AM
darbleinad's Avatar
Car: 84 Trans Am
i have read that it helps to unbolt the motor from the mounts and jack the motor up a bt. i will be installing mine in a couple of weeks when school is done.
Old Mar 31, 2003 | 11:56 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Which tube did you have to dent to clear the plug? Do you have straight plug heads?
Old Mar 31, 2003 | 12:28 PM
Car: 99 Formula
Axle/Gears: 342
I had to dent the front primary tube on the # 1 cylinder I believe it was.
I have straight plug heads, but for some reason, the plugs angle down a bit, where as angle plug heads slant to the sides.
Old Mar 31, 2003 | 12:44 PM
Camarokid01's Avatar
were these shorties or long tubes?
Old Mar 31, 2003 | 12:45 PM
Car: 99 Formula
Axle/Gears: 342
long tubes
Old Apr 1, 2003 | 09:26 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
What do you have planned for the rest of the system under the car?
Old Apr 1, 2003 | 09:34 AM
Car: 99 Formula
Axle/Gears: 342
For now, it's just going to be S turns with pipes going into a Flowmaster Y-Collector into my Hooker cat-back , with no cat this time. Depending on how it performs I'll most likely stick with that.
Old Apr 1, 2003 | 10:17 PM
MdFormula350's Avatar
congrats
Old Apr 2, 2003 | 10:01 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
cant wait to hear some sound clips.
i cant wait to do my full hooker exuast.
Hooker supercomp longtubes coated
mufflex ypipe
and Hooker cat back
Old Apr 2, 2003 | 10:03 AM
Car: 99 Formula
Axle/Gears: 342
mufflex ypipe
and Hooker cat back
will the mufflex y pipe hook from the long tubes directily into the cat-back?
Old Apr 2, 2003 | 10:05 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
the way ive seen pics it looks like it should but if u get there y pipe u need the reducer to go back into the old i pipe.
Old Apr 2, 2003 | 10:10 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
heres the 4in openin at the end of the y pipe
Old Apr 2, 2003 | 10:11 AM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
heres a pic with the reducer u need ot buy inorder to mate it to the 3in catback.
Old Apr 2, 2003 | 10:16 AM
Car: 99 Formula
Axle/Gears: 342
how much is it?
Old Apr 2, 2003 | 02:39 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
its $250 for just the y pipe and then $25 for the adaptor. it cost me $327.53 shipped to my door but it took them forever to bill it and then send it. and as far as i know it only hooks up to the hooker supercomp long tubes.
and in those picks that just 2 pieces of the system theres more to it then just that of chorse
Old Oct 1, 2003 | 10:25 PM
biff85ta's Avatar
Car: 04 Vette
Hey Mark you got any pics of your setup????
Frozer!!!
Jan 19, 2024 04:55 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
theurge
Aug 21, 2015 12:46 PM
bryan623
Aug 10, 2015 11:33 AM
