tpi vette manifolds
Old Sep 26, 2003 | 08:10 AM
nick harmon's Avatar
Car: 91 RS
Engine: LO3
tpi vette manifolds
need to know if tpi vette manifolds will fit my f-body. also am i correct that the vette mans are 2.25 or 2.5 outlets compared to the f-bodys 350 mans, 2.0
Old Sep 26, 2003 | 07:36 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
def wont fit
Old Sep 27, 2003 | 03:28 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Are you talking about those "header-ish" manifolds? The ones on my uncle's Corvette are tubular center-dumps. I think they will work fine, they just won't bolt up to your stock exhaust system, if thats what you are asking.
You'd just have to have a Y-pipe made (or yours modified) to come up pretty much dead center between the #4+6 and #3+5 cylinders.
Would probably take some real creativity to do though.
And yes, the outlets on the Corvette manifolds are quite a bit bigger than the F-body manifolds. Not sure of the exact size though.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Hawkeye1980
Aug 31, 2015 07:09 AM
theurge
Aug 21, 2015 12:46 PM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
