Looking for a high flow catalytic converter
Old Oct 5, 2003 | 04:58 PM
86blkbird's Avatar
Car: 1988 Formula now a T/A
Engine: LB9
I am looking for a direct fit high flow cat setup for my 88 Formula. It has a 305 TPI with AIR. It will need to match up to an Edelbrock TES header y-pipe combo I am installing. the y-pipe has a 3 inch outlet. Any particular brand/ part number I should look for? Prices?
Old Oct 5, 2003 | 06:54 PM
Chet's Avatar
Car: GTA
I just bought a direct fit 3" high flow catco a few days ago from summit for $116. Here is the part #CTO-9118.
Old Oct 6, 2003 | 09:07 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
catco is the one i just had put on... cat remember the number but its connects right to the edelbrock y-pipe no problems... jsut make dure it has the AIR tube and youll have no problems..
Old Oct 6, 2003 | 09:27 AM
bigals87z28's Avatar
Car: Check The Sig
same here.. only i got a uni-cat. I had to do some fabbing but it all worked out and I passed emissions with it. Its a great cat if you need one.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Dialed_In
Aug 20, 2015 01:45 PM
Fronzizzle
Aug 19, 2015 01:36 PM
